4020 John Deere Tractor 3pt Hydrolic system not wo
Leodis
10-03-2006 22:23:34
I have a 4020 John Deere tractor that when using the power lift it doesn't stay were you set it. For example if I am mowing it will either go down or up it never stays exactly where you want it to be. Also when I turn on the PTO it trys to ingage the tractor to drive forward as if i'm not holding the clucth at times. Also sometime to get the PTO to work I have to put the tractor in gear and drive forward before PTO ingages. The hydrolic pump located infront of tractor was rebuilt but problem still accurs. What would be a starting point to diagnosing this problem?
Bob
10-04-2006 21:14:11
 Re: 4020 John Deere Tractor 3pt Hydrolic system no in reply to Leodis, 10-03-2006 22:23:34
Does this tractor have a power shift transmission????
buickanddeere
10-04-2006 20:05:04
Hydraulic
Tx Jim
10-04-2006 03:17:54
On 3 pt movement if control handle doesn't move while operating, the L&D control needs to be in "D" position and probably L&D assembly adjusted internally. The actual engagement of pto has nothing in common with hyd pump but main clutch and pto clutch are bolted in an assembly and have to be adjusted correctly to operate correctly. Granted later 4020's pto valve operates from transmission pump. TxcJim
leodis
10-04-2006 12:47:07
 Re: 4020 John Deere Tractor 3pt Hydrolic system no in reply to Tx Jim, 10-04-2006 03:17:54
The pto isn't my biggest concern but I thought that these problems could all indicate whats causing the problem. U know, 1 solution could fix them all. But ur saying that the pto and 3pt are to different systems, ok. So whats could be a solution for the 3pt system? Ur saying its just a matter of doing some adjustments internally. What exactly do I need to adjust and location? Whats L&D?
Tx Jim
10-05-2006 04:30:43
 Re: 4020 John Deere Tractor 3pt Hydrolic system no in reply to leodis, 10-04-2006 12:47:07
L&D is load and depth sensing that is built into the 3pt controls. There is a short lever on RH side of rockshaft housing under seat close to your right heel while setting in seat. Put lever in "D". If adjustments need to be made you need a JD tech. manual as the adjustments are a little complicated to perform. Tx Jim
Leodis
10-05-2006 11:02:58
 Re: 4020 John Deere Tractor 3pt Hydrolic system no in reply to Tx Jim, 10-05-2006 04:30:43
Yes I will get the manual and I'll look that section up and learn more about it. Hey thanks alot!
Leo
