39 b
Wayne Co
10-03-2006 21:30:16
We bought a 1939 B and it has an after market 5th and 6th gear bolted on behind flywheel, are they very common?
DickD
10-04-2006 17:29:15
 Re: 39 b in reply to Wayne Co, 10-03-2006 21:30:16
We had a 39B, and we installed a Behlen gearbox on the left side behind the flywheel. To operate it the main shift lever had to be stationed in neutral. Then shift the lever for the Behlen gearbox in gear. With the hi-lo lever in low was 5th gear and in hi position was 6th. If you haven't found out already, be D--- careful where you station your hands when starting the hand crankers, as they are a finger eater, with this gearbox.
David from Kansas
10-04-2006 06:35:13
Wayne,
I've seen several of those on A's and B's so I don't think they are "rare" by any means.
