3020 gas stopped....won't start
Illinois Farmal
10-03-2006 17:21:53
The other day I was using my 3020 gas to pull my corn picker when it started sputtering, then backfired and then quit. Couldn"t get it started then. It"s never really run right since I got it from a dealer this summer so I called them out again to look at it. The mech that came out changed the plugs, cleaned the rotor/cap and tweaked the carb some. Finally got it going but it still seemed to run a bit rich. He thought the carb was worn and needed to be rebuilt. After he left it ran strong for about 30 minutes and then suddenly died as if someone turned off a switch. Now it won"t start again. Now I"m no mechanic by any means but this doesn"t sound like a carb problem to just suddenly die. Could a coil that is bad/going bad cause this. Any help would be greatly appreciated!
Gerald J.
10-03-2006 23:58:25
 Re: 3020 gas stopped....won't start in reply to Illinois Farmall, 10-03-2006 17:21:53
My 4020 did that while raking hay one summer. Turned out its ignition had been rewired sometime to use an external resistor on the coil instead of the one in the ignition switch and the added run ignition wire used a Scotch-tap to make its connection. That d..... Scotch-tap was loosing contact. It would fire while cranking because there's an added contact on the starter solenoid that puts power direct to the coil for better starting. I hot wired it for the day and finished the hay making.
Otherwise, if I don't regularly oil the points pivot in the distributor, once every couple months the points won't close and it stops. I fiddle with the points and it runs for weeks or months at a time.
Be sure the lift pump is pumping to the carburetor, not the crankcase. My 4020 got so it would only run if the gas tank was above a 1/3 full. An electric pump fixed that, and the oil in the crankcase seems to not stay full, as if the old pump was dribbling a bit of gas into the oil.
Gerald J.
TimS in Mo
10-03-2006 21:46:46
Check the basics, fuel flow, spark, etc....
Dieing that suddenly points to a sudden loss of fuel or spark...is there some debris in the tank plugging the fuel line?
Is the coil getting hot and not producing spark?
Check and let us know.
Glen in TX
10-03-2006 17:39:05
Did it have good fire after it died? Check that. If no fire then suspect the coil, wiring or condenser. Good fuel flow to carb? Old Marvel Schebler USX carb or a better Zenith?
Illinois Farmall
10-04-2006 04:38:16
 Re: 3020 gas stopped....won't start in reply to Glen in TX, 10-03-2006 17:39:05
How can you tell the difference between the 2 carbs? Mine appears to have an aluminum body with no name/castings on it. For what it's worth, the dealer has pulled the carb and is going to rebuild it.
Mike M
10-04-2006 04:42:57
 Re: 3020 gas stopped....won't start in reply to Illinois Farmall, 10-04-2006 04:38:16
A waste of time/money to rebuild that carb.
The cast iron Zenith ones are the ONLY one to have on there.
Forgot to add
10-04-2006 04:44:48
 Re: 3020 gas stopped....won't start in reply to Mike M, 10-04-2006 04:42:57
I don't think you main problem is the carb. if it runs good then dies. A carb. problem would run bad all the time.
