60 Charging question
Wind
10-03-2006 04:20:50
When I bought the tractor, the previous owner sent along a new switch as it does not always want to start in the run only position. Change to the lights on position and it will start, but the battery is not getting a charge. Are the two somehow related? Or should I be looking further down in the system? The regulator is not a stock part and I do not think the generator is original either. The battery box is pretty well shot and I was also wondering if being grounded to the battery box is not getting a complete circut. TIA
Wind
Wind
10-04-2006 04:44:57
 Re: 60 Charging question in reply to Wind, 10-03-2006 04:20:50
OK, to answer all the questions that were asked. The battery is still hooked up as positive ground. Not sure about the generator being original, but suspect it is not. Will start when jumped, and keep running, so must be getting enough juice to keep the system going, just nothing going through the amp meter to the battery. Guess I need a wiring diagram to see where all the connections are correct or not. Do know that the prevoius owner only had it for a year and put in a new battery, so that probably got him through a year OK as he did not run it much. Looks like I need to get out the meter and start checking.
Don c
10-03-2006 11:28:57
I have a diagram for a early 60, neg. ground that Clooney had sent me, e mail me if you want or need it. Don c
Glen in TX
10-03-2006 08:42:39
You might try it with new switch and also move the battery ground and check regulator and generator mounting grounding also. Also check with a diagram to see if it's wired right. It was originally positive ground. It may be negative ground now since you mention generator and regulator are not original and maybe just the amp meter leads need reversing ? Is it charging good 12.5-14V at the battery ?
55 50
10-03-2006 07:59:21
If it starts, then your ground at the battery box has to be OK. Be quite thankful that you got a new switch with the tractor as they are expensive, 47.77 in 2003. If it's wired correctly, then the charging circuit does not go through the ignition/light switch and your positioning of the switch differently isn't related to the non-charging.
Larry 2809C
10-03-2006 05:45:07
I too have a JD 60 that will not start on the run position. If I switch it to the "light" position, it will start and then i switch it back to the run position and it will show a charge. It may pay you to have the gen and reg checked out.
