DLTX 3 Carburetor questionsI have been having trouble starting my 1929 D #75049 I asked a question about this before. Here is a link so you can see what I asked and what was suggested. Link I think most of the problem is in the carb but I do have low compression, at least in the left hand cylinder as it is the only one I checked. I can�t turn it over hard enough by hand to even get my compression gage to read. With the crank case cover off, turning tractor over by hand at compression stroke I can here air escaping into the crank case. I assumed this meant air was leaking past the rings but just now I thought maybe a valve is leaking and I hear air in the crank case coming through where the push rods are. I�ll have to check that. Now one to the carb. The carb was rebuilt 10 years ago and just recently been used for the first time. I do not believe the carb was rebuilt right so I am doing it again myself. In the previous post I mentioned Branson�s rebuilt my carb, I was wrong someone else did the work. Here is a list of question I hope some of you can answer. 1, When the LOAD needle is closed it does not seal perfectly. I plugged all the ports and blew air in where the bowl nut screws on and it leaks slightly where the load needle taper seats in the carb. Is this ok? If not how do I fix it? 2, There are two steel? Plugs soldered in the carb just below where the top of the bowl would go. What are these and should I take them out and clean in there? 3, I noticed the choke shaft, throttle plate and throttle shaft bushings are steel, would it matter if the choke shaft and throttle shaft bushings where brass or do they need to be dissimilar metals? 4, Does anybody make throttle shaft bushings that are slightly over sized in the OD? Anybody willing to make me some? I would do this but my lathe is down. 5, The throttle plate has two small flats opposite each other on the OD in line with the shaft, is it suppose to be this way? I notice the choke plate does not have these flats. 6, It looks like some places sell brass float needles and some sell steel ones, which should I get? 7, The ball detent load side part of the casting was missing and I machined it out and solder in some new brass and machined it for a new ball and spring. Anybody have any ideas how I can finish the surface of the new brass so the texture matches the carb casting? Our help in this is greatly appreciated. Bruce
