JD model 44 trip plow
AllanR
10-02-2006 21:24:42
I cant remove the wheel on the trip side of the plow, I took off the cap, bolts and pin, but the wheel will not slide off. The wheel on the other side came right off. Is there something I need to do to get this wheel off. The wheels are spokes.
Bobl1958
10-03-2006 06:43:34
 Re: JD model 44 trip plow in reply to AllanR, 10-02-2006 21:24:42
If you feel for some reason you still have to get it off, you can jack it up so it's off the ground a little, apply pressure from the backside with a bar or wedge (helps to have a second person, but not required), and give a good rap on the end of the axle with a sledge hammer. It should pop right off. Good luck. Bob
ET
10-03-2006 06:10:00
The wheel is pressed on to a cone center. If all you are doing is changing the tire and painting the rim just do it on the plow. Its easyer to get the tire off on the plow because you don't have to chase the tire around the floor as you pry.
