Fuel Tank Repair
Cotton
10-02-2006 17:06:32
Are there any products on the market to repair small pinholes (internal rust) on fuel tanks?
Cotton
P Browning
10-02-2006 18:21:46
 Re: Fuel Tank Repair in reply to Cotton, 10-02-2006 17:06:32
Cotton -- Yes indeed. There is KREEM, Red Kote and POR 15 to name three products. There is a product review on KREEM somewhere on the www.ytmag.com website, and you can read a little more about the subject at the JD-H Restoration Site. Go to the site, and on the left - scroll down & one-click on SHEET METAL. Scroll down to about the 80% point of that article to the heading of LINING A FUEL TANK. The process is outlined in brief, leaving you some room for interpretation.
Cotton
10-02-2006 18:58:49
 Re: Fuel Tank Repair in reply to P Browning, 10-02-2006 18:21:46
Thanks for the information, It is simple and straight forward
ebbsspeed
10-03-2006 19:11:38
 Re: Fuel Tank Repair in reply to Cotton, 10-02-2006 18:58:49
In my experience the Red Kote is a much better product, I've had the Kreem delaminate from the tank sides before, never had that situation with the Red Kote.
http://www.damonq.com/TechSheets/Red-Kote.pdf#search=%22red%20kote%20sealer%22
F-I-T
10-04-2006 12:46:22
 Re: Fuel Tank Repair in reply to ebbsspeed, 10-03-2006 19:11:38
I also think Red Coat can be dissolved with the appropriate solvent (see text below), so if you do have to get it out, it will. I had seen two tanks with Kreme problems similar to yours.
From a "Red-Kote" supplier site:
"Red-Kote � is a new polymer coating developed by Damon Chemical. Red-Kote � is resistant to gasoline, diesel fuel, alcohol and other fuel additives. Its major use is to seal leaking fuel tanks.
Solvents such as methyl ethyl ketone (MEK), acetone, methylene chloride and propylene oxide (POP) will completely dissolve the polymer. Other industrial solvents may affect the coating but not completely dissolve it."
Cotton
10-05-2006 05:35:16
 Re: Fuel Tank Repair in reply to F-I-T, 10-04-2006 12:46:22
Thanks to all for the info.
Cotton
