Countershaft removal, '50A, 677xxx
njs
10-02-2006 09:24:18
Have the hsg on the right off and the nut off on the left side. I just cannot budge the gear on the left outside. Cannot seem to get just the right puller (tight quarters) and it looks like the key is cocked a bit which would add to the tightness on the shaft. I believe I have to get that gear off 1st, then the snap ring, then the brg on the right side to pull out the countershaft from the left. I am at a standstill. And I thought the wheel hubs were tough!
machinery-man
10-02-2006 11:53:47
 Re: Countershaft removal, '50A, 677xxx in reply to njs, 10-02-2006 09:24:18
behind the gear there should be a plate then a locking ring and the shaft and bearing will pull out. Pretty simple once you see what"s happening inside these transmission...the real trick is tightning up the lower shaft by removing shims or you might need to replace bearing on right....
machinery-man
10-02-2006 11:46:26
use some heat, accetylene torch and the gear will pull right off...do it the easy way as those are 0 fit parts. Be careful and not bugger the thread of the end...leave the nut on the end position...
Kurt_JDB
10-02-2006 10:27:17
Are you talking the sliding shaft (top shaft) or the countershaft (bottom shaft)? On the 51B the gear on the left side is on the sliding shaft (top) Anyway,
That gear can be a real bear to pull. I broke two pullers trying to get this gear off my 51B before I went out and rented a really high quality gear puller. I think I used a two jaw puller setup. The more expensive pullers are made from better steel, and the depth of the jaw is thinner, and will fit behind the gear. I have seen some of the service manuals for a B tractor indicate that this gear has two threaded holes in it that you can use to pull the gear by running two bolts in and tighting the bolts and forcing the gear off that way. Mine did not have these holes. I would worry a little trying to get it off that way about uneven pressure on the two bolts.
I beleive the A transmission is set up like the B, and you do have to get that gear off to remove the shaft.
Good luck,
Kurt
Mike M
10-02-2006 10:51:28
 Re: Countershaft removal, '50A, 677xxx in reply to Kurt_JDB, 10-02-2006 10:27:17
I have seen those B's with gears both ways. I really like the ones with the threaded holes as they are alot easier to get apart.
