41 JD LA - back firing
Rick in Mi
10-02-2006 08:10:20
I've cleaned the carb, gas line running to the carb and changed gas. I've checked the points and timing. Engine starts easy and will re-start without problem. If I play with the choke it appears I can minimize the back firing, but still doesn't run right. Any ideas what could be causing this problem.
Tom N OK
10-02-2006 10:20:33
 Re: 41 JD LA - back firing in reply to Rick in Mi, 10-02-2006 08:10:20
Hi Rick I would check the gap on the points. Not having enough gap is usually the reason for backfiring. Blowed a muffler up on a car once.
Mike M
10-02-2006 09:58:38
If you for some reason are running around with the air cleaner unhooked it will cause it not to run right. I had this problem on my LA when I swapped engines around and wanted to test run it before painting and putting everything back together.
JAS
10-02-2006 09:36:28
What about the plugs? Even if they look good, I'd put a set in.
dab
10-02-2006 09:14:21
Out of time?????Maybe.....
CPeter
10-02-2006 09:27:53
 Re: 41 JD LA - back firing in reply to dab, 10-02-2006 09:14:21
Pull the plug on the bottom of the carb and insure that you DO have a good flow of gas, a pencil sized flow for at least 30 seconds. It sounds like it is starving for gas.
CPeter
