35 Loader control parts
Wes Burns
10-02-2006 03:21:23
Where can I find parts to rebuild the control valve on a 35 loader. The lift control is leaking. Can find replacement parts. The loader is on a 2010 John Deere
Hayfarmer
10-02-2006 07:18:45
 Re: 35 Loader control parts in reply to Wes Burns, 10-02-2006 03:21:23
I have a #35 on my JD430 and had the same trouble a few years back. Not much inside the valve think I got the O ring from Deere but it was a special one. I think there were also different valves used on those and unless you know yours was original, it may have been changed. I think mine is just kinda worn out from too many ups and downs over the years.
Henry M
10-02-2006 04:48:00
Wess
Did you try mother deere? Possibly you could get into the valves and find that it just needa and O Ring which could be matched at the local parts/hardware store.
Another way, if you want to spring for it would be to replace the valves with modern ones. I put a modern one on mine. Gotta make sure the valves have their own relief that matches the tractor system.
