85 - 140W gear Lube for a 48-A tranny?
Sam Schudi
09-29-2006 20:28:15
Can I use a multi-weight (85W-140) Gear Lube for a 48 JD-A transmission? Multi-Weight is all I can find at the local Fleet Farm.
Plus, is there just one drain plug on an A?
Thanks,
Sam
machinery-man
10-01-2006 06:45:10
 Re: 85 - 140W gear Lube for a 48-A tranny? in reply to Sam Schudi, 09-29-2006 20:28:15
I always use straight 140W. That oil originally used was heavy and thinner oil will get by those old axle seals. If you use the thinner leave a gallon or so out.
Pappy
09-29-2006 20:51:16
The "A" has two drain plugs. You need to remove both to get all the oil out. 85-140 will work just fine. One of the drain plugs is a standard pipe plug type and the other is recessed and needs a 3/4" tool such as a 3/4" socket handle.
Sam Schudi
09-30-2006 06:40:43
 Re: 85 - 140W gear Lube for a 48-A tranny? in reply to Pappy, 09-29-2006 20:51:16
Great news, now I can get her done today.
Thanks for the help!
Sam
