JD 60 Polarity Problem?
wolfman
09-29-2006 19:11:09
What did i mess up this time? JD 60 totally restored, new wires terminals, etc. Replaced battery with new 12 volt positive ground. Before replacing battery, I must have used starter-charger on old bat & now wonder if I put cables on backwards?? If I take cover off the regulator & physically close points, the gen charges; let go & no charge. Also system really insists on disconnecting. Turn switch to ON, guage shows a little discharge, touch the starter & gauge goes to zero and no go. Disconnect both bat cables & re-connect might start properly. Next try, same problem. You don't even hear a little hiss at the terminals. Could the polarity have gotten reversed? Or am I missing something? other than a brain.
dan hill
10-15-2006 04:44:18
 Re: JD 60 Polarity Problem? in reply to wolfman, 09-29-2006 19:11:09
If closing the cutout points by hand makes it charge you have an open shunt coil in the cutout relay.This fine wire coil closes the cut out point when the generator starts charging.The coil is wound under the large wire cut out coil,You may find a bad solder joint at the start or the winding or at the ground end.If you find the winding open a new regulator will fix.
John T
09-29-2006 20:00:45
Im just not sure sittin here what you may have done, but insure the NEW battery is wired Positive ground, then just to be sure Polarize the Genny again, then clean n wire brush n check and reatatch both the battery cables and the ground cable to where it bonds to the tractor frame/ground,,,,,You may need to check n tighten the battery cable down on the starter switch also.
The fact that removing n reconnecting the battery cables chanhes things reallyyyyy y makes me wonder about those cables and/or connection to the battery posts. Its possible for cable ends to look okay but be burned n carboned under where you cant see it CHECK THOSE CABLES N GROUNDS !!!!!
After (concerning the charging problem) that I would insure BOTH the genny (especially after a painting the ground may be bad) and VR have good grounds maybe run a jumper wire from the grounded battery post to the genny and VR n see if that helps.
The next thing I cant e sure of is which portion/realy of the VR youre manualy closing, the Cutout Relay or the Field Control Realy??
Why dont you try to dead ground the gennys Field post when shes running at fast RPM n see if she charges okay then but NOT otherwise?? If so the VR is bad (field control portion) OR the VR isnt well grounded OR the wires bad from FLD on genny to VR's FLD terminal
If dead grounding the gennys Field post dont help, leave it grounded then by pass jump the VR's cutout relay portion by momentarily jumping the BAT terminal to the ARM (or GEN) terminal n see if she charges then?? If so but NOT otherwise, the VR's Cutout Relay may be bad
If the battery is installed backwards (polarity got changed) in the tractor and the genny wasnt correctly polarized, it can do a number on the VR
If the main problem is the starters not always cranking, that can well be a bad connection or ground or bad cable or cable end, but my advice above to remove n clean n wire brush n reattach all the battery n ground n starter switch cables might cure that!!! ASSUMING the battery is okay?????
If depressign the starter dont cause the lights to dim way down and/or the battery voltage drop a lot but she still dont crank, the starter switch or the post on the starter under that switch may be the cause. But if the lights dim when you try n crank it and/or the batery voltage drops a lot, then I suspect the switch is okay but the starter itself may be the cause.
Lemme know
John T
wolfman
10-03-2006 19:20:54
 Re: JD 60 Polarity Problem? in reply to John T, 09-29-2006 20:00:45
John T; I think you were right on. I got a longer one guage ground cable and ran it out the bottom of the battery box and attached it to a bolt on frame (after I used grinder to get area around bolt hole shiney-stuffed small rag in hole to keep any grind spirs out). Also got a new wire for the gen to regulator-old one was likely a 1955. Re-attached everything and she started right up. So far, three good starts. Just in case, before starting I did momentarily polarize the regulator. Shows a wee bit of charge at half throttle or more. Shows discharge with lights on. Thanks John T. The old ground wire and lower connection "looked good". Where it was attached at bottom of battery box was likely the problem. Wolfy.
