1010 rus John Deere Head Rebuild
Jeff McBride
09-29-2006 18:33:17
Can anyone tell me where I can get a valve train set for my 1010 so I can rebuild the head. It is a 315 CID 3 1/2" bore 3" stroke. This site only has them listed for 145 Cid and Value Bilt Tractor don't list them at all. I am going to call my local dealer tomorrow but I don't think they can get them. I was hoping someone knew a good place to order them from.
Thanks Jeff
jjamna
10-11-2006 16:33:58
 Re: 1010 rus John Deere Head Rebuild in reply to Jeff McBride, 09-29-2006 18:33:17
Sounds like rings to me Have you checked the compression? I had the Head done at a local shop $100 put in rings and rod bearings about $150 and gasket set $130 and it made it run 100% better. good luck
mvick
10-11-2006 15:07:38
I am after some general help on a JD 1010 (gas) as well. It has a loader and backhoe. It starts and runs good but has a good amount of blow by and very little power. It stalls out at full throttle going up a hill in low gear. Any suggestions on where to start? thanks
jdemaris
09-30-2006 16:04:22
If you've got a 315 cubic inch 1010 - it's pretty rare. Hopefully, you mean a 115 if a gas engine. 145 is the diesel 1010 or a gas 2010. You can buy the exhaust valves on this website. Exhaust is Part No: TP-T12357. I know they only mention the 145 engine - but it's the exhaust valve for either the 115 gas engine in the 1010 or the 145 gas engine in the 2010. Same goes for the valve guides. Last time I looked in the catalog down at the local machine shop there were two companies selling the valve-train parts for the 115s - either individually or in sets. But the two last 1010 gas engines I did valve jobs on - one needed nothing other than to be reseated, springs shimmed back up to proper installed height, and new valve seals. The other needed all new exhaust valves and guides but the intakes were fine after being reground. I wound up buying them from this website although my Deere dealer could also get them. 1010 heads are pretty easy to work on and the guides are replaceable with no machining. A couple of hour's work if you have a valve-refacer and seat-cutter. That is - unless you need new seats. The diesels need a proper valve-head depth in head maintained so you cannot grind the valves or seats too much. With the gas - it is not critical. So sometimes the gas heads don't need a lot. Intakes are Deere part # T12356 and exhausts T12357. Farmerline has the T12356 valves for $13.88 each and the exhaust valves for $17.46 at Link
Jeff McBride
09-30-2006 17:36:15
 Re: 1010 rus John Deere Head Rebuild in reply to jdemaris, 09-30-2006 16:04:22
I guess a 315 would be very rare- yes it is a 115.
The only thing that is wrong with it is valve seals (I think). It ran fine but when you first start it up it smokes bad. If you let it run at low rpm it still smokes. The only way to make it stop (or slow down a lot) is run it at full throttle and work it, after about five minutes of this it clears up. Is it possible to just change the seals? Or do you want to put guides in also. As you can tell this is my first time doing this. This is practice for a 4010 diesel.
Thanks Jeff
jdemaris
09-30-2006 18:07:11
 Re: 1010 rus John Deere Head Rebuild in reply to Jeff McBride, 09-30-2006 17:36:15
Putting valve seals in is a fairly easy job - and without taking head off. Just do one cylinder at time. Take the spark-plug out and, and install an adapter fitting with an air-chuck on it. Then, put compressed air into it. An autoparts store will usually have adapters just for the purpose - or you can just make one. Spark-plug thread on one end and an air-chuck on the other (to plug your air-hose into). Once the air is hooked up, the valves cannot go anywhere. Now, you can take off the valve keepers and springs, intall the new seals, put all back on. One other tool you'll probably need - which also used to be very common - is a little valve-spring compressor made just for this job - it has little side-jaws on it and a thumb-wheel on top. Same tool is also used a lot for small engine repair. A conventional - C-type valve spring compressor doesn't work except with the head off. Back in the days of small-block Chevy V-8s making smoke all over - it was our #1 repair job. Up to the late 70s, Chevy didn't install any valve seals when new - just little o-rings to seal the valve-spring retainers. So, once the valve guides got just slightly worn - they'd burn oil like crazy going down hills, de-accelerating, or at first start-up. So, we had to add umbrella seals. Now Chevy et. al. use positive-control stationary valve-seals. Not unbrella seals (that go up and down with the valves) but a seal that is fastened to the top of the valve-guide and is stationary. It has a teflon insert that is the friction surface and rides against the valve stem. Nowadays, with the strict emmissions laws - I think all automotive engines have to use them. Funny thing is - this is what the 1010 has as standard equipment. Wierd - considering Deere wasn't using it on anything else I've seen at the time - and the 1010 wasn't exactly known for "cutting edge" technology. The seals come with a little plastic sleeve to help in installation. The seals fit tight enough over the valve stem that they can get cut when first pushing on. Thus the starting-sleeve. If you need more specific answers - let me know. If you need to buy the adapters and/or compressor - I know that KD (el cheapo tools) has them.
jjamna
09-30-2006 10:33:08
I am going to take it to a machine shop. I just thought I would need to provide the parts. I haven't found anyone who has parts for this motor.
MSM
09-30-2006 01:14:24
Your best and easiest solution is to take the head to a reputable machine shop.Unless you have a fully equipped machine shop at home you will most likely be money ahead.You may not need all new valves,guides and seats that comes in a kit.Unless the head is totally trashed it shouldn't cost over $300 to have it done correctly.
