 Maybe a minor detail, but I'm pretty certain that the bearings on the sliding shaft are all straight roller bearing type. There are no cups listed along that shaft in the parts books. The counter shaft has all tapered bearings. Been there done that. It's easiest accessed by splitting the tractor between the main case and the rear axle housing. Any time you do, you should perform any work or adjustments that you can. I would raise and block the rear end so the wheels can turn and listen carefully with a garden hose stethoscope at the outside first reduction gear bearing. It's behind the cap cover on the outside of the first reduction gear cover about 10" behind the pulley. Those do not oil well at all and while they can be pretty quiet during a no-load situation like clutch engaged, transmision neutral, if that bearing is going bad, it can can be rocking back and forth during an intermittent load downhill run, causing a growl. This shows up quiet often when pulling a wagon that is constantly moving toward and then away from the tractor. ALso, since the counteshaft has the tapered roller bearings, that shaft would be still during clutch engaged, transmission neutral, so any noise there would only show up with tractor in motion....I think. I did not take the time to trace the power transmission paths which are illustrated in the newer service books. If you can look at a 70, single stick service manual diagram you'll be able to see the flow of power from the clutch to the first reduction gear across the sliding gear shaft, down any particular gear to the countershaft, to the differential to the bull gears. Going from memory here..... .. Frank
