Ist time paint job
mike
12-15-1999 10:41:42
I've got a 46 G that I want to paint, never done it before. Is steam cleaning and then air spraying w/JD green on the tractor acceptable? Or do I have to sand and prime? Someone else is gonna straighten out tinwork and spray for me. This not gonna be a showpiece, but I would like it to look nice and more importantly LAST. Also I have a 48 G that is real nice. That one,(next project)I would like to look real nice. Any difference in paint jobs/prep? Also , where do you get good decals? Thanks and Happy Holidays to all! Mike
JDBob
12-16-1999 07:22:54
 Re: Ist time paint job in reply to mike, 12-15-1999 10:41:42
Mike, I'll have to agree with Mark on the decals. The only ones I know of that look like the originals are from Travis Jorde. The decals you get from the dealer or other places for $20-$30 aren't right. They have the clear tape between the letters and just don't do justice to a fresh paint job.
As for the paint job, if your just wanting a nice look to use around the farm I'd sand the sheet metal lightly, degrease (Oven cleaner works well), and fix oil leaks and use primer sealer and spray JD green. If you want a show shine, I'd sand her all the way down and use a good quality paint such as DuPont and do Base Coat Clear Coat, and top it off with a set of Jordes decals.
Hope this helps a little, It's been my experience that your better off not to go cheap on the paint or decals, because it'll just start looking old again much quicker and all your work is lost.
JDBob
mark
12-15-1999 14:17:18
decals are best obtained from Jorde Decals, or from K&K Antique Tractor Parts.
goatman
12-15-1999 12:59:02
mike i painted my 1010 in oct'98 and it still looks very nice. all i did was degrease everything replace all leaking seals, sand all sheetmetal, seal all bare spots and thats pretty much it. did remove frt. wheels and used old shower curtains to cover rear wheels. got all my decals from dealer they are'nt costly and well worth it. hope this helps and good luck!!!!! !!!
