47 B ser.202333
dougn
09-29-2006 12:12:17
looked at a b for sale yesterday. owner told me it had a front wheels, they are 5.5x16 tires.rear tires are mismatched 9.5x42 and 11x42 with cast centers. any idea what they came off of?
dougn
09-29-2006 17:26:58
 Re: 47 B ser.202333 in reply to dougn, 09-29-2006 12:12:17
thanks,JD KNOW IT ALL. what would the casting number be for a hi clearance or regular B? would the serial tag show anything special?
JD KNOW IT ALL 2006
09-30-2006 12:55:33
 Re: 47 B ser.202333 in reply to dougn, 09-29-2006 17:26:58
HI AGAIN, THE NUMBER ON THE REAR AXLE FOR THE HIGH CLEARANCE B IS B2406R. IF YOUR NUMBER DOES NOT MATCH, YOU DON"T HAVE A HIGH CLEARNACE. ANOTHER EASY WAY TO TELL IS THE HIGH CLEARANCE TRACTORS HAD VERY LONG AXLES. SEE IF YOURS ARE LONG OR IF IT LOOKS LIKE THE HAVE BEEN CUT. MANY PEOPLE CUT THE AXLES BECAUSE THEY WERE SO LONG. GOOD LUCK.
Ten-Twemty
09-30-2006 05:37:21
dougn,
The rear axle housing casting number for the regular row-crop Model "B" is B2405R. The casting number for the high-clearance Model"BN" and "BW" is B2406R. Let us know which you have.
JD KNOW IT ALL 2006
09-29-2006 13:36:57
YOU HAVE A HIGH CLEARANCE B JOHN DEERE ACCORDING TO THE REAR TIRE SIZE. IT SHOULD HAVE EITHER A WIDE OR SINGLE FRONT WHEEL, OR SOMEONE MAY HAVE PUT THE 42'S ON THE BACK OF YOUR B. YOU CAN TELL IF IT IS A TRUE HIGH CLEARANCE B BY THE CASTING NUMBER ON THE REAR AXLE.
john hajek
09-29-2006 13:06:41
Have 48 B. looks like John Deere to me.====John
