4020 powershift problems
super red
09-29-2006 10:47:25
My 4020 when I shift it will stop between the last two gears and when I use the clutch it wont is there something wrong with the clutch pack in the powershift ? how hard is it to fix ?
Gerald J.
09-29-2006 17:37:37
 Re: 4020 powershift problems in reply to super red, 09-29-2006 10:47:25
There are no gears shifted in the 4020 powershift. There is no clutch. All the shifting including the inching pedal (that one on the left of the pedestal where a synchro range has a clutch pedal) works with clutch packs. Not shifting right might be a sign of wrong oil pressure, or dirt in a complex valve or wrong oil.
Gerald J.
super red
09-29-2006 18:24:52
 Re: 4020 powershift problems in reply to Gerald J., 09-29-2006 17:37:37
between the last two gears while shifting it will come to a complete stop before taking off in the high gear it will just about throw you over the steering wheel . but if I push the clutch in while shifting it wont stop. something must be sticking or would the powershift be going bad ?
Gerald J.
09-29-2006 20:11:16
 Re: 4020 powershift problems in reply to super red, 09-29-2006 18:24:52
I'm no powershift expert. But I do know its all controlled by hydraulics, so the first thing I'd do is replace the oil and filters as well as the suction screen. Best I recall from scanning the power shift sections in my 4020 shop manual is that the "clutch pedal" (really the inching pedal) just dumps hydraulic pressure from three clutch packs. So if there's something plugging that drain or valve it might be a sign of junk all over such as from a brake disk from using the wrong oil.
Gerald J.
super red
09-30-2006 06:24:30
 Re: 4020 powershift problems in reply to Gerald J., 09-29-2006 20:11:16
I will change the oil and filters and see what happens. thanks for the info.
