JD 2750 Clutch Problem
ol' guy
09-29-2006 06:01:37
A few days ago I power washed the tractor like many times before. Now the clutch is frozen--won't release (disengage). A dealer service tech tried to get it "unstuck" but couldn't. The dealer service mgr. says the tractor must be split to fix it. (New clutch was installed about 400 hours ago.)
Any ideas??? A neighbor suggests I should (very carefully) run it into something solid and "shock" it loose. Your thoughts appreciated.
low budget
09-29-2006 18:15:25
 Re: JD 2750 Clutch Problem in reply to ol' guy, 09-29-2006 06:01:37
Recently purchased a 7700 Ford with exactly the same problem, powerwashed and clutch stuck, so I got it cheap. Stabbing the brakes did not work for me. Here what I did: Prop the clutch pedal down. Remove starter for access, spray brake-clean onto clutch, rotate engine using screwdriver on flywheel to get brake-clean all around the clutch. Use a punch of some sort to tap on the pressure plate (I bent an old rake tooth to use as a punch) Rotate engine to get all the way around the pressure plate. Left it sit over night with clutch pedal depressed. Next day I put the starter back in and fired it up and the clutch worked perfectly. If it doesn't work you can try stabbing the brakes again or repeat the process. Its worth a try before splitting the tractor.
Mike M
09-29-2006 06:10:09
I've had real good luck with the trick of getting it going pretty fast in an open area then jab on ONE brake pedal and usually after a few times the clutch comes loose. You need to hold the clutch pedal down (I use a block or wire) and hang on as the tractor will really jerk.
I learned this over at the 8N Ford board and it has worked very well for me.
Kurt_JDB
09-29-2006 08:27:00
 Re: JD 2750 Clutch Problem in reply to Mike M, 09-29-2006 06:10:09
A trick I used to use on my old "51 chevy truck to unstick the clutch was to jack up one of the rear wheels (after blocking the other wheels), start the engine with the truck in gear, rev it up and then slap on the brakes while holding the clutch in. Worked every time.
Take all precautions, and think over what might happen if the vehicles falls off the jack while it is reved up. Obviously this won"t work if you have some other problem, and I also recommend caution with regards to possible tranny damage.
Kurt
Kurt
