Flamethrower Coil
Dave in SV
09-27-2006 18:01:45
I need to replace the coil on my '49A. Is the Flamethrower a good choice? I am told that it is a 12 volt coil, and it does NOT need an external resistor.
Lee B
09-27-2006 22:25:45
 Re: Flamethrower Coil in reply to Dave in SV, 09-27-2006 18:01:45
There is a FlameThrower II coil out there now which has .5 ohm resistance and MUST be used only with the module made for it - be sure you don't get this one.
But if you are talking about the standard 3 ohm FlameThrower by Pertronix, then yes it will be a very good coil to use either with it's own module or standard points set up as my 44A has. It is a 12 volt coil and does NOT need a resistor, so you were told right. I am able to run it with .080" spark plug gap using champions and it has not missed a lick in three years of hard pulling. Going for $40 currently, you will be hard pressed to spend money for a coil and get a better return on it.
I noticed an immediate difference in the way the engine no longer misses at idle thru full load in my 59 chevy (235), bobcat (ford industrial pinto engine), and the 44A, all using standard points and condensers. I will NOT buy a standard 'parts store' coil ever again!
buickanddeere
09-27-2006 20:06:45
Carefull putting that Ultra Mega Blitzburg Flameblaster Turbo Coil on there. That A will start making HP like a 720/730.
john dear
09-27-2006 19:56:25
I agree with below. If it is 3 ohm you won't need a resistor. You will have to open the plug gap to about .055" to see any real increase in voltage. A million volt coil with a .025" plug gap won't spark any hotter than a 20,000 volt coil with the same gap. Spark energy builds up until it can jump the gap. The higher voltage coils can jump a large gap and are more apt to jump if the plugs are wet or oily. It very well may start better with the Flamethrower.
dan hill
09-30-2006 04:14:21
 Re: Flamethrower Coil in reply to john dear, 09-27-2006 19:56:25
The coils output voltage is a complex wave form.It will usually jumps the spark plug gap when the voltage climbs to 10000 volts.The 40000 volt coils are BS.The ignition wires would break down at 40000 volts.A Snap On meter that reads spark voltage will prove this.Fence chargers that produce a 10000 volt pulse can jump a 3/8 gap in open air.A 40000 volt pulse inside a distributor cap would fire all cylinders at the same time.
John T
09-27-2006 18:55:40
Dave, That "Flamethrower" coil (if its the Pertronix one Im thinking of) is a high energy coil intended more for an electronic ignition switch I believe, but if youre still using points n condensor to switch the coil current, it wont really gain you all that much improved performance (maybe some cuz its more efficient). In fact, if its a low impedance coil intended only for an electronic switch that can handle n switch higher currents, it may even HURT you cuz if it draws more current the old fashioned mechanical points will burn up prematurely.
HOWEVER I dont know its specs (especially its primary winding resistance) so check with the Vendor, and if its like a 3 ohm or so primary (like a stock 12 volt coil) then it will NOT draw excess current to overcurrent the points and it will NOT hurt nuttin, but again, with the points n condensor used to switch coil current dont expect any major improvement just cuz you use that or any other high performance coil.
As long as its still the old fashioned mechanical points n condensor youre NOT gonna gain that much performance increase from a high energy coil, its when you couple a high energy coil with an electronic switch that you can reallyyyyy yyy gain in performance.
If you go with a regular coil and are at 12 volts with NO external series ballast resistor, be sure n get a true full 12 volt rated coil, it may be labeled "12 volts" or "12 volts No ballast required" HOWEVER DO NOT use a coil labeled "12 volts for use with ballast resistor" unballasted cuz its in reality a 6 volt coil and without the external series ballast it will run hot plus the points will burn up prematurely. If, however, you wanna use a voltage dropping (12 to 6) external ballast resistor and have a 12 volt tractor, then you need a 6 volt coil.
John T
ChadS
09-28-2006 08:01:18
 Re: Flamethrower Coil in reply to John T, 09-27-2006 18:55:40
You can take a Accel Super stock coil, 12 volt, which is around 40,000 volt, you can either use the coil without a resistor, it works, but burns up points if they have the small contacts, coil gets warmer than I like to see, so I run a resistor,, the coil does have a hotter flame, more than a stock 6 volt coil, if I had to guess, it would be like having a 10 volt in a 6 volt package,, (cant say 12, cause its not 12 volts,,) Alot of the problem is having too big of alternator,, if you put like a chevy 65 amp one wire alt,, thats way more power than what it really needs, I wonder sometimes if thats why they get so hot without a resistor,, Ive ran em with alternators, (gets warm) and just off the battery, and its cooler to the touch. Ive found that having a good 12 volt system, that charges what,,, say 13.5v,,, which is alot of power for that coil,, with points, cut the power back to fine tune the parts, if you could get it to where the coil works, without burning point contacts, and the coil, slightly warm to the touch,, not hot,,,, it will have more at the plugs,,,,, than say a stock 6 volt, I thnik that a resitor that can cut the voltage back to around 10-11 volts peak, would be perfect,, but,, do they make such a thing? Chad
John T
09-28-2006 08:20:23
 Re: Flamethrower Coil in reply to ChadS, 09-28-2006 08:01:18
Chad, Yeppers thats the deal on some of those high energy coils, they are designed to draw more current then the 4 amps or so max that points like to switch without burning up too soon.....yet the elec switch can handle the higher switching current plus do it faster and more positive for better energy transfer and more spark gap energy expended across the plugs gap for better combustion initiation....
Of course, I dont care if the super coil is rated to 80,000 volts, it still only ramps up high enough to arc gap current across the plugs gap, no higher, and the voltage required to jump the gap is a function of the medium (fuel and compression) and the plug gap sooooo given the same conditions it wont fire at any highher voltage then a stock coil, its just capable of doing so if the conditions warrant it
Thats why I always recommend to get the most bang for the buck out of an elec switch is to couple it with a high energy coil and run a wider plug gap, but if youre still using points to switch the coils current, regardless how the coil is rated theres only so much gain that can be realized.
Fun discussion, take care now
John T
Dave in SV
09-30-2006 04:39:33
 Re: Flamethrower Coil in reply to John T, 09-28-2006 08:20:23
WOW! What a lot of great info!!!
Bottom line: should I use a Flamethrower or a stock coil? If I use a Flamethrower, am I going to chew up points quicker? I don't compete, I just use the '49A for hayrides and country drives with the kids.
There's nothing like the sound of an old Deere laboring up a country dirt road hill!
ChadS
09-28-2006 08:57:45
Thats the deal right there,, The electronic conversions, dont allow the coil energy to pass thru the trigger, it reroutes it thru the coil, acts as a signal. So, no high voltage to burn up the trigger. The voltage doubles, when the condenser is gone,, and that is what makes a high enery system, cause now you have full volatge from the coil, where a traditional system with points and condensers will only use half the coil output, so it dont burn up the contacts, absorbs the excess energy right? and a resistor on the coil helped it even more,, Exactly on the the plug gaps,, sometimes, if the coil is too hot and the plugs are not gapped, it may short out before it reaches the plug,, or its so hot of fire, it does jump the gap, but shorts out somehow, not all of the power goes thru the electrode. usually the short is the point gap, or the cap towers short between themselves, carbon tracking,, etc etc. It dont take a real high energy coil, just a fine tuned setup, proper adjustments, checks n balances ya know,, Chad
Dave in SV
09-30-2006 04:41:28
 Re: Flamethrower Coil in reply to ChadS, 09-28-2006 08:57:45
Please see the post I just sent to John... and "DITTO" to you!
