48 JD-A Drawbar Tongue weight?
Sam Schudi
09-27-2006 15:41:19
Has anyone ever pulled a tandem axel trailer right off the drawbar with a 2-5/16 ball? If so, how much tongue weight can the drawbar carry?
I would like to use the 3-point but it will not hold position and drops slowly, unless you hold the lever in the up position.
Thanks,
Sam
Mike M
09-28-2006 05:58:31
 Re: 48 JD-A Drawbar Tongue weight? in reply to Sam Schudi, 09-27-2006 15:41:19
What kinda trailer ? If a house trailer I'd get at least a 4020.
Smaller trailers should be no problem just check the drawbar assy. bolts for tightness and run it up short and use bolts drawed up tight in the cross piece too. The drawbar will hold ,but that front end will get light and unsafe at some amount of weight.
Sam Schudi
09-28-2006 13:46:05
 Re: 48 JD-A Drawbar Tongue weight? in reply to Mike M, 09-28-2006 05:58:31
Guess I should have mentioned, I am planning to pull an 18 ft. tandem axel car hauler. The trailer is about 1,600 lbs. empty with about 200 lbs on the tongue. I want to give some hayrides in the field at slow speeds. Not sure but it could see 500 lbs or a little more on the tongue with 20 people spread out, but it could be less too. Still should not be a problem?
