? about 46 AR JD
mark harvey
09-27-2006 10:54:05
1. What did the r stand for
2 What mag did this tractor come out with,
3 did they have one brake or two , mine has one but a frinds tractor has two,
thank you
JPatton
09-27-2006 20:25:10
 Re: ? about 46 AR JD in reply to mark harvey, 09-27-2006 10:54:05
Mark - Glen has the story correct below. The "R" stood for REGULAR. In other words, most tractors of that era were Row Crop. B, A, etc. So by adding the R to the A or B, that signified a Regular tread, wheatland type tractor. The "O" designation was for Orchard as Glen has explained.
Hope this helps
J
JD AR
09-27-2006 17:12:51
In my owners manual, it says it came with one brake, and two was "optional".
Glen in TX
09-27-2006 12:18:48
AR & BR tractors were lower profile standard tread tractors like a wheatland. AO & BO were orchard models but same low profile and standard tread. AR has same engine and many other same parts as row crop A model but trans case housing and axles are different. That model would have came with a Wico C-1042 magneto but a later Wico XH-1042 replacement mag would be fine on it too. You'll find info on the brakes in unstyled JD A parts catalog PC674.
mark harvey
09-27-2006 12:50:24
 Re: ? about 46 AR JD in reply to Glen in TX, 09-27-2006 12:18:48
thankyou
