John Deere G Head gasket
Gman
12-14-1999 19:25:34
Need a U/S G head gasket am told the bore diameter is just a tad larger than a styled G head gasket,or a copper head gasket and installation procedure of the copper gasket. Gman
Dan
12-14-1999 19:55:51
 Re: John Deere G Head gasket in reply to Gman, 12-14-1999 19:25:34
Check with Lubbock Gasket Supply. The will custom make the gasket if you do not find it. 1-800-527-2064 fax 806-763-0965 Hope this helps
Gman
12-17-1999 18:13:28
 Re: Re: John Deere G Head gasket in reply to Dan , 12-14-1999 19:55:51
Thanks Dan been intouch with them,thought I might try to get by on n.o.s. But I'veabout decided to use the solid copper gasket and wire. thanks gman
