4020 jumps out of reverse
georg
09-26-2006 19:13:14
4020 john deere and it jumps out of reverse. Is this a common problem? A john deere mechanic says it is the syncronizers. Any ideas on what might the problem be?
Glen in TX
09-27-2006 11:48:28
 Re: 4020 jumps out of reverse in reply to georg, 09-26-2006 19:13:14
That spring assembly piece in linkage gets full of dirt and just won't let you adjust like it should be over time and other linkage and bushings gets worn on quadrant under dash and rods worn. Like Gerald said check all that and get it in good shape before going inside. You'll find help on adjusting in a I&T shop manual or JD service manual and can view the parts catalog online also for it.
JD publications 800-522-7448 or http://techpubs.deere.com
Gerald J.
09-26-2006 19:44:47
It could be the synchronizers, it could be the linkage from the dash to the shifter cams is worn and not getting it all the way into gear, it could be the cams are worn and not getting it all the way into gear. Wear from not being all the way in gear won't help it stay in gear.
The linkage is a whole lot easier to fix than stuff inside the transmission and the linkage is adjustable.
Gerald J.
