G muffler same as A?
Gwiz
09-26-2006 18:44:55
The muffler on my '49 G is too short. I just scanned around the net to see how much to expect to pay for the correct height. Is the G muffler the same as the A muffler? Same inside diameter, overall length, dent in side?
Seems like it should have a larger inside diameter for an engine with 100 more cubic inches. What's up with the shorter ones? I need to match the air intake which I'm assuming is 24" or some I see advertised as 24 1/2"
Thanks
James Martin
Rusty Junk TX
09-27-2006 03:31:26
 Re: G muffler same as A? in reply to Gwiz, 09-26-2006 18:44:55
The G muffler (styled and unstyled) and the Unstyled A all use the same 24" no dent muffler. K&K Antique has the correct one. You can get a muffler, one that looks like a muffler even at the top but no guts, or a straight black pipe. I think they are $42.50 and take your pick of the three.
Marcus
Pappy
09-26-2006 22:56:07
You need a muffler without the dent fot the "G".
If you use the dented one, it won't look right.
CLW
09-26-2006 20:27:10
Most folks get upset becouse they can't find the correct muffler for the A. I think they are 20 1/2 inches tall. You might look for one for a 60, 620, 70, 720. They were taller than the A muffler and have the dent.
P Browning
09-26-2006 19:02:44
For the JD-A tractor, from 488000-up, the muffler call out is AA2214R, and much to my surprise -- it is AA2214R for all of the JD-G tractors! And so for all JD-A 1940 & up, they are the same part. (PatB)
