Dave, Yeppers if the coils primary winding is open (ought to be between 1.25 and 3.5 ohms or so depending on its voltage rating) its bad, likey got too hot from being left on as you mentioned..... The reason for a "resistor wire" (but I wonder if you really have one???) and/or a conventional bathtub style external ballast resistor (whats normally used versus a resistive wire link or a thermistor wire) would be to reduce the coils input voltage from 12 volts (on 12 volt tractors) down to 6 for operating a 6 volt coil so it doesnt draw too much current and overheat and also to reduce the current the points must switch to prevent them from burning up prematurley. Deere and others used 6 volt coils on some later 12 volt equipped tractors so thay had to use an external voltage dropping (12 to 6) Ballast Resistor so the coil didnt overheat as noted immediately above. The other alternative was to use a true full 12 volt rated (some call internally ballasted) coil with no external ballast required. As far as replacement parts, many Central Tractor or Rural King or Tractor Supply stores plus Mother Deere, of course, carry them in stock, just be sure and buy the correct replacement coil..... .If youre at 12 volts and use an external voltage dropping (12 to 6) Ballast Resistor you would need a 6 volt coil. However, if you DO NOT have any external series Ballast Resistor, then you need a true full 12 volt rated coil. NOTE a true 12 volt coil may be labeled "12 Volts" or "12 volts NOT for use with external ballast" BUTTTTT TT caution a coil labeled "12 volts requires external ballast" is in reality a 6 volt coil and WOULD REQUIRE a Ballast if on a 12 volt tractor. NOTE Even if NOT original equipment and you use an external ballast resistor with a 6 volt coil, I would recommend a start by pass system which sends full unballasted battery voltage to the coil ONLY at start up and then its voltage drops back to the 6 as required for normal operation. That would involve simply a starter switch having that extra lil side terminal which is hot ONLY when the starter switch is engaged and a wire ran from it up to the coils input terminal. John T
