Hydraulic fluid question ...
JPatrick
09-26-2006 16:46:51
Bled the brake lines on our JD2555, and then topped off the reservoir with 3 gallons of what I thought was good fluid. It now appears that the fluid I used was a couple of years old, and had a black particulate intermixed with the normally amber colored fluid. So, is it time to drain the 18 gallon reservoir, and fill it with new fluid, or charge ahead and not be concerned about the black stuff in the older fluid?
Thanks in advance for all opinions.
JP
MSM
09-27-2006 10:09:38
 Re: Hydraulic fluid question ... in reply to JPatrick, 09-26-2006 16:46:51
If it was mine I would dump the fluid,and change the filters.Otherwise you may be back on here in a month asking why the hi-lo quit working or why it won"t steer or why won"t the remotes work or .....
JPatrick
09-27-2006 17:15:14
 Re: Hydraulic fluid question ... in reply to MSM, 09-27-2006 10:09:38
Thanks for the suggestion. I was pretty much convinced that draining the reservoir was the only reasonable option. JP
