Creeping cylinder on 4010 scv
TimS in Mo
09-26-2006 10:32:12
On our 4010, the right side scv will slowly extend the tongue on the disc conditioner as I'm mowing with it. I looked on jdparts, it looks like they have an overhaul kit, I assume this has new orings and packings, do you think this might help?
Since it extends so slowly ( probably would take a couple minutes to extend all the way ) I was thinking its a minor leak past an oring or packing maybe?
I guess a valve seat could be worn leaking some high pressure fluid into that valve..?
Gerald J.
09-26-2006 11:45:19
 Re: Creeping cylinder on 4010 scv in reply to TimS in Mo, 09-26-2006 10:32:12
That rebuild kit is for the connectors, not the valve. The valve is located up on the engine firewall, upper left. It uses poppet valves with an intricate linkage. It may be adjusted (there's a chapter on it in the shop manual) but more likely the valves and seats have worn from use and vibration and will need to be reground or replaced, Then the valve has to be readjusted with feeler gauges and the like. I don't think there are any o-rings in the valve at all.
Gerald J.
TimS in Mo
09-26-2006 12:10:32
 Re: Creeping cylinder on 4010 scv in reply to Gerald J., 09-26-2006 11:45:19
The diagram for the parts kit showed the valve, not the coupler...
Here is the part number for the kit, from the diagram it looks like it has o-rings and packings.
AR34295
ET
09-26-2006 12:29:55
 Re: Creeping cylinder on 4010 scv in reply to TimS in Mo, 09-26-2006 12:10:32
That is a packing kit you have the number for but, to fix the leaking valve seat it has to be ground and the valves ajusted with a special fixture and a dial indicator. Your best bet is to take the valve to your dealer and hope they have someone that understands how to fix them. I had one to a 4020 back to the dealer 3 times to get it right.
