1950 A Generator
gurneejoe
09-25-2006 20:33:28
I took my generator in to be checked and rebuilt and the rebuilder has it set up as 12v neg ground. Are they normally pos ground or has someone possibly changed the system? If it is supposed to be positive ground which terminals are shorted to polarize it correctly?
John T
09-26-2006 07:02:19
 Re: 1950 A Generator in reply to gurneejoe, 09-25-2006 20:33:28
The genny will charge at EITHER Pos or Neg Ground once its polarized one particular way. Before you fire her up and assuming you have the battery installed Positive ground as you indicated and the Voltage Regulator wired up, use a jumper wire and momentarily flash jump the BAT and GEN (or ARM) terminals together and you should get a small spark. If you dont get the spark perhaps the genny doent have a good frame ground connection (check n insure that) and/or the gennys Field post isnt getting a proper ground via the Voltage Regulator, you might wanna temporarily connect the gennys Field post to ground before you polarize just in case, but its usually NOT necessary.
You can polarize the genny (maybe what the shop did???) even without the VR wired up by having the genny grounded and momentarily flash jumping hot voltage (like as found on the VR's BAT terminal) direct to the gennys ARM post to get the spark.
All 2 cylinder Deeres originally were Positive ground. They sometimes got changed by accident which would require the ammeter and coil leads to be reversed or else the ammeter would read bass ackwards n the coil not to run as efficient. Again, the genny couild still charge at either polarity if it were polarized
Post back any questions
John T
gurneejoe
09-26-2006 16:10:27
 Re: 1950 A Generator in reply to John T, 09-26-2006 07:02:19
Thanks for the help. Joe
