3 bottom plow
Adam Conner
12-14-1999 16:35:08
I have been looking at a JD 3-bottom moldboard 2-way (rollover) plow. In one of my books there is a picture of an 825 plow which looks very similar to this one. The only difference that I can see is that on the one that I am looking at has a straight tube frame which the moldboards are connected to vs. the bent steel frame of the 825. The number on the frogs (shanks?)of the one I am looking at are A13799A. Does anyone have an Idea of what model plow this may be and during which years it was produced? I plan on hooking it to my 730 LP, what do you all think? Thanks for your input! ADAM
Dean Van peursem
09-25-2002 10:40:12
 Re: 3 bottom plow in reply to Adam Conner, 12-14-1999 16:35:08
The plow you are looking at is a model RO516. It was made from 1968 to 1976 and is a very heavy plow intended to be used with the new generation tractors. It may be a tad heavy for your intended usage as the front end my get a bit light.
garvin
12-16-1999 13:04:25
I have a 3 bottom roll over which has the bent frame, and according to my neighbor who worked for Deere at the time these plows were made, they were built for the 730.
Gman
12-14-1999 19:08:49
Adam these rollover plows make the front end sort lite don't they,I got a set of 3-14 trailer plows with hydraulic cylinder (555 ABH) boy are the sweet to plow with,I'm looking for a set of 4-14 for my 70 LP STD. the trailer plows take a little more room to turn around in. Later Gman
Chad WInk
12-14-1999 22:46:43
 Re: Re: 3 bottom plow in reply to Gman, 12-14-1999 19:08:49
I plowed 100s acres with a 4-14 555ABH, I still have it. I used a 720 Diesel or a 70 Diesel.
