620 rockshaft stuck
BobinKS
09-25-2006 17:48:09
The rockshaft lever on my 620 will not move. I removed the linkage and the actual lever moves but the actuator does not. It is in the full raise position and when the tractor is running the 3 point goes up but I can't lower it. When I shut the tractor off the hitch slowly lowers back down. I tried adjusting the rate of drop and put it in the middle but it had no effect. Any suggestions would be great.
John VB
09-26-2006 05:34:44
 Re: 620 rockshaft stuck in reply to BobinKS, 09-25-2006 17:48:09
My 620 has the same problem. I don't have a 3-point so I haven't messed with it. Inside the housing, there are LIKELY some pieces stuck together. Perhaps corrosion or crud. A parts manual will show everything in there. You have to pull the seat pedastal and cover to get at it and free up the stuck pieces. Hopefully that is all that is wrong.
