60 clutch drive disk spinning independant of crank
Fred from MO
09-25-2006 10:44:28
I heard a grinding noise coming from the clutch on my 60 and it stopped pulling. I shut it off and upon inspection all clutches appear to be in good shape. I have not removed the bolt that holds the clutch drive disk on the crankshaft yet, but I noticed it is spinning idenpendantly of the crankshaft. Without pulling the drive disk off (which I intend to do) does this movement mean my crank splines are shot? Fearing the worse!!
Thanks
F-I-T
09-25-2006 11:01:28
 Re: 60 clutch drive disk spinning independant of c in reply to Fred from MO, 09-25-2006 10:44:28
Fred:
It could be that the bore of the disk is cracked from side to side and it came loose from the crank as a result of that.
Or, your crank splines could be shot.
You have to perform an autopsy find the truth.
Frank
Fred from MO
09-25-2006 11:06:36
 Re: 60 clutch drive disk spinning independant of c in reply to F-I-T, 09-25-2006 11:01:28
Thanks Frank, Lets keep our fingers crossed that it is just the drive disk. Do you know the cost of repair on the splines of the crankshaft if it is that. I remember seeing posts of a place to have this performed in the past.?
