51 A Engine Overhaul
Steve Abner
09-24-2006 16:02:03
Ok, so I got to inspecting this thing and the exhaust has been uncovered for some time, I pulled alot of clear water and I think what looked or smelled like Marvel oil out of the cylinders. It won't bar over though. What could I expect to have the engine rebuilt at JD here in AZ or does anyone recommend someone in the Wickenburg/Wittmann area? S/N 681207
Steve
F-I-T
09-24-2006 17:09:26
 Re: 51 A Engine Overhaul in reply to Steve Abner, 09-24-2006 16:02:03
Steve:
If you have even a minor mechanical aptitude and some pretty basic tools, that's a nice winter job for the do-it-yourself-er. That is an engine that a lot of pretty good shade-tree mechanics started on. Parts are large and easy to handle and it's a common model so replacements are widely available both new and used. Adjustments are simple, and you only have two cylinders so you won't 16 of anything if you pour it all into a box.
At today's shop rates, and given that most techs are not current on something 55 years old, I'd say you could have $2,000 in it before you could blink. Then you have to figure that most of the labor you will pay will be to educate your mechanic up to a minimum grade of competence. You will be able to buy a running tractor in more than good condition for that shop bill, in my VERY humble opinion. BTW, I overhauled our '48 "A" in the summer between 7th and 8th grade, even poured my own babbit at the local blacksmiths shop, went through the carb and distributor ignition, repaired the charging system, and it went to use that fall on the plow. That engine is still in use today.
Give it a shot. It's a very simple engine.
Frank
Steve Abner
09-24-2006 17:27:31
 Re: 51 A Engine Overhaul in reply to F-I-T, 09-24-2006 17:09:26
Thanks Frank for the advice. I'm a 15yr Power Generation field tech for Cummins Rocky Mountain, my electro-mechanical knowledge is really strong and this sounds like it would be fun. Now I really can't wait for those books!
F-I-T
09-24-2006 17:32:44
 Re: 51 A Engine Overhaul in reply to Steve Abner, 09-24-2006 17:27:31
You'll really like the task. You get to buy tools for a reason, and say things like:
"Well, hon, that dress will have to wait. WE (caps for affect) have to get a Mac 400 ft-lb torquewrench first..."
Stan - Florida
09-24-2006 19:32:59
 Re: 51 A Engine Overhaul in reply to F-I-T, 09-24-2006 17:32:44
Frank,
You've always got the good answers!!
Spent a night at A Camper's World a month ago. How close was I to your house? Couldn't find your phone number in my 'puter 'til I got home.
Going to Moultrie this year?
Stan - Melbourne
F-I-T
09-24-2006 20:30:21
 Re: 51 A Engine Overhaul in reply to Stan - Florida, 09-24-2006 19:32:59
Stan:
I doubt it. It always lands in the middle of the week and I will likely be on the road. I'm still struggling to get the inside of my building organized. I'm nearing completion of my A/C'd work room. Now I'll have a place to cool off when it's hot out on the prairie.
Is Camper's World just off of I-10 and Route 19? If so, I was the next exit (Lloyd), and about 3 miles north.
Stan - Florida
09-25-2006 04:23:21
 Re: 51 A Engine Overhaul in reply to F-I-T, 09-24-2006 20:30:21
Good luck on the new shop...that will be nice in the summer, for sure.
Yep, A Camper's World is at the I-10 exit at Hwy. 19.
Stan
