4850 Oil Pressure Light
Howard H.
09-23-2006 20:25:03
Hi All -
Is there any trick to fixing a faulty oil pressure dash indicator on a JD 4850??
Dad has had 2 different JD mechanics (who really know their stuff otherwise) out 4 different times and neither has figured out the problem.
It reads correctly intermittently as you speed the engine up, but goes to "dead" or 0 while actually working.
We hooked up a Murphy gauge into the cab (which shows correct/good oil pressure) and go by it for right now.
One JD man said there was a recall correction from JD on it and that he now knew how to fix the problem - but then spent all afternoon and still didn't get it fixed...
Thanks for any advice/info!
Howard H.
