B oil line
Gene-WI
09-23-2006 07:06:09
I had the camshaft break on my B so tore everything apart and put another cam in, but now I can't get the oil line that goes to the governor reconnected, when the cam broke it must have bent the line, I've tried for days taking the line out and bending it slightly but no luck I thought about making a new line out of copper but the only fittings I can find are the sleeveless type and I'm afraid if I take the fitting out in the crankcase I'll never get a new fitting back in. Hard, working with only one hand and my fingers aren't as flexiable as they used to be. I was going to get a new line from JD but $56 seemed a little much. Any Ideas would be greatly appreciated. Thanks Gene
Lee B
09-23-2006 13:58:47
 Re: B oil line in reply to Gene-WI, 09-23-2006 07:06:09
Those fittings just sweat on with solder so the copper line could be replaced using the old fittings if it came to that. If you do this be sure to clean out all the old solder and use plenty of liquid flux and tinning flux so that the new solder sticks solidly to the insides of the brass fittings. That oil soaked, old solder in those brass fittings is really a challenge to re-solder without lots of tinning solution.
I would undo the bottom fitting so as to connect the top fitting so that I could see exactly which way the line needed bending, and then line it up pretty darn close. Then tighten up the bottom connection first as it would be the hardest one to get the threads started right. A new line would probably need the same treatment anyway. Got any youngsters around you can talk into doing you a favor?
