'49A Starter doesn't always engage correctly
Dave in SV
09-23-2006 03:13:05
Quite often, when depressing the starter pedal, the starter drive doesn't mesh to the flywheel gear... resulting in an awful growl (from the tractor and from me!). Weird thing is... it doesn't do that when the flywheel cover is off. Flywheel gear bevel is backwards from what the books call for. Is that the problem? Do I need to adjust the linkage? Is the hole in the flywheel cover somehow deflecting the starter pedal shaft travel (sure doesn't appear to be)?
mr.thinker
09-23-2006 19:21:25
 Re: '49A Starter doesn't always engage correctly in reply to Dave in SV, 09-23-2006 03:13:05
try looking at your pedel and linkage, night be bottoming out on cover, or binding somewhere?
Dave in SV
09-23-2006 19:23:31
 Re: '49A Starter doesn't always engage correctly in reply to mr.thinker , 09-23-2006 19:21:25
Good idea... I think I'll do just that!
P Browning
09-23-2006 14:10:07
Dave -- There's a shot in the dark for you to consider. Go to the JD-H Restoration Site (below), and whence there, one-click on ELECT SYSTEMS. Allow time for the PDF document to come up, then page on in (I think) to page 4 for some discussion (albeit brief) on troubleshooting the starter. On pages 4 & 5 we see the notion of perhaps needing to shim the starter to establish correct alignment. This same technique applied to many earlier model cars as I can recall. It may help. (PatB)
Dave in SV
09-23-2006 19:26:56
 Re: '49A Starter doesn't always engage correctly in reply to P Browning, 09-23-2006 14:10:07
As I just confessed to another gentleman, I should tell the rest of the story: the growling didn't start until I had the starter rebuilt. Maybe the way I reinstalled it has something to do with it? I don't recall any shims when I removed it... so there were no shims used upon reinstallation.
As always, Pat, thanks for the insights and help!
Lee B
09-23-2006 13:39:39
That is weird, and I'm not sure what to make of it, but for the most part replacing the bendix drive is about the only 'tip' I know of. In other words, your situation doesn't have a common, well known cure outside of a new bendix drive and/or re-bushing the starter bearings.
If a new bendix drive doesn't cure the problem THEN there is really something to post about. Bendix should be engaged into the flywheel teeth before the juice hits the starter so even a turned around ring gear would still work alright IF the bendix was a good one so I don't think that is the problem. It's utterly amazing how many odd symptoms are cured with a new bendix, and every time it happens, I can only shake my head in disbelief.
Dave in SV
09-23-2006 19:22:05
 Re: '49A Starter doesn't always engage correctly in reply to Lee B, 09-23-2006 13:39:39
OK... here's the rest of the story, now that you mentioned the Bendix drive: this growling problem did not exist until after I had the starter rebuilt (which involved a new Bendix drive). Maybe I remounted the starter in a way to cause this? Assuming the new Bendix drive is (was) good, how do I check it?
Mike M
09-24-2006 13:05:35
 Re: '49A Starter doesn't always engage correctly in reply to Dave in SV, 09-23-2006 19:22:05
Then there is always a chance the "new" drive is no good. These are to ratchet one way maybe yours is slipping ???
P Browning
09-24-2006 08:30:19
Classic Generator (Delco-Remy parts) may be a source you will need. (817) 473-1448 is a phone number, or try him at the website listed below. (PatB)
F-I-T
09-23-2006 19:26:47
Dave:
Are you SURE the rebuild shop installed the correct gear tooth pitch/count/etc. drive? There are a lot of drives that will fit, but if your drive pinion beometry is not an exact "multiple" in all ways, of your ring gear (which is a rack if it is laid out straight), then you have the same interference as you would turning a metric nut onto a standard bolt.....
Found more than one like that over the years.
Frank
Dave in SV
09-23-2006 19:30:41
 Re: '49A Starter doesn't always engage correctly in reply to F-I-T, 09-23-2006 19:26:47
Shucks, I don't know! I'd better look into that! Pitch/count, etc.?!?!? Geometry?!!?!? How in the heck do I determine all of that???? Maybe I still have the old one that was removed... and can compare the two. Otherwise, I may be in deep doo doo.
F-I-T
09-24-2006 10:28:20
 Re: '49A Starter doesn't always engage correctly in reply to Dave in SV, 09-23-2006 19:30:41
Dave:
What was "wrong" with the old Bendix mechanism, or did your shop just recommend that you replace it?
Dave in SV
09-25-2006 03:35:23
 Re: '49A Starter doesn't always engage correctly in reply to F-I-T, 09-24-2006 10:28:20
I can't remember the reason... something to do with the ratchet feature not working propoerly, I think.
