Gear shift JD- H
Notminiacres
09-22-2006 20:11:15
Went out to take my 1941 for a little ride a fewe days ago, and, something has came loose or broke in the gearshift. It now is able to be pulled up and out of the shifting forks down in the trans. What part do I nee to get to correct this. You can still shift it but have to hold down on gearshift lever to keep it in the shifting forks. Many thanks to all who respond.
Ernie
P Browning
09-23-2006 02:12:17
 Re: Gear shift JD- H in reply to Notminiacres, 09-22-2006 20:11:15
Go to the JD-H Restoration Site. One-click on TECHNICAL ISSUES. Then go to page 10, "REBUILDING THE GEAR SHIFT". This is a very common problem. (PatB)
jdhbag
09-22-2006 20:35:32
Sounds like the snap ring below the ball on the shift lever has popped out of the grove and letting the ball slide down the shift lever.
MSD
09-22-2006 20:44:13
 Re: Gear shift JD- H in reply to jdhbag, 09-22-2006 20:35:32
If the ball is still on the lever and it comes out, you will need a new socket. Be sure to get a new seal boot to keep the water out of the tranny.
Notminiacres
09-22-2006 20:49:38
 Re: Gear shift JD- H in reply to MSD, 09-22-2006 20:44:13
The ball is still on the lever and won't come out. Thanks for your response.Got another reply, thinking the snap ring has came off. Checking it out tomorrow. Thanks EVERYONE!!!
