730 diesel electrical problem
Deere Heaven
10-29-2003 07:13:16
I am wiring up my 730 and I cant seem to get all the lights to work. I have a new wiring harness from Deere, new switch, and rebuilt the lights. I hook up all the wires according to the schematic and tried the lights and only the right hand side light comes on. So I switched light wires and the left came on and the right went out. On the back of the switch you have two terminals marked BAT A and B, I Switched them and got the same results only one side. Am I missing something or is somthing wrong. Thanks, Brian Austin, Texas
Deere Heaven
10-29-2003 12:06:36
 Re: 730 diesel electrical problem in reply to Deere Heaven , 10-29-2003 07:13:16
I understand now. I need to have power to both BAT A and BAT B. Currently I only have it to BAT A by the blue wire. How can I get it to the other terminal? Is This due to the converson of 4 six volt batteries to two 12 volt batteries? Is there a need to run a wire from the batteries to a ground on the tractor? Thanks guys, Brian
Clooney
10-29-2003 15:35:00
 Re: Re: 730 diesel electrical problem in reply to Deere Heaven , 10-29-2003 12:06:36
Brian, YES, you need battery power to BOTH the ign switch's [BAT A] & [BAT B] terminals.... If your brown wire is now dead it is either open or hooked to the wrong place on the starter or regulator,,, OR, you don't have the short battery cable between the 2 batteries. You obviously have the center ground wire hooked up [at least to one battery]... ~Bottom line,, IF your tractor cranks then the batteries are hooked up properly & IF one set of lights operate you have the center battery ground hooked up...
~SO, that leaves the brown wire as the problem..... MAKE SURE it is hooked to the second battery cable at the starter, then to the regulator stud, then to the ign switch [BAT B, I believe]... The blue wire is powered from the other battery cable at the starter solenoid stud....
[email protected]
John T
10-29-2003 15:04:32
Youre gonna get there Brian no problemmmmm mm.
HOWEVER, DO NOT run any more grounds to the batteries OTHER THAN the mid tie point in the middle of the 4 batteries where they join
{+ to -} and are bonded to frame ground. The 4 batteries are (+) - + {- +} - + (-) for 4 in grnd
series equals 24 volts from the two outermost terminals (+) (-) and 12 volts from either outermost terminal to frame ground since the mid tie point where the 2 center batteries join {- +} above is grounded. Clear as mud????? The center tie point {+ -} MUST BE GROUNDED HOWEVER, is yours now????? ???? Its those 2 lil black wires on the diagram I posted that are attached to the frame ground.
The A and B are the (+) and (-) as shown above.
You asked how do I get the other (A or B) to the switch to power the remaining lights, well look at the wiring diagram. It looks like the 2 wires intended as the A and B feeds are the Brown wire and the Black wire off the starter solenoid BUT my diagram confuses the Blue and one of the Blacks up there off the solenoid so Im unsure what you have on your tractor?????
REGARDLESS its wires somewhere from the 2 big cables to the starter that eventaully get to the A and B feeds that become the A and B on your switch regardless of colors. Each of the A and B up to the switches input must show 12 volts to ground, one happesn to be pos other neg. The lights fed from one will not work unless theres 12 volts on the switches A or B input.
Youre gettign there, if this dont work I volunteer my friend Clooney to come fix it.
Good Luck John T
buickanddeere
10-29-2003 10:18:47
With the 24V starting/charging system, 1/2 of the lights/instruments are 12V positive ground and the other 1/2 of the lights are 12V negative ground. There's supposed to be + & - 12V to the switch. And a tie to chassis at the middle point of the batteries.
Deere Heaven
10-29-2003 11:04:05
 Re: Re: 730 diesel electrical problem in reply to buickanddeere, 10-29-2003 10:18:47
How do I go about wiring it this way?
Deere Heaven
10-29-2003 09:41:52
I have a wiring schematic and every thing is hooked up as it says and the wires are hooked up correctly. I only have the lights on the side not on the fenders. The blue wire is the hot wire that connects to the BAT A terminal. The other wires that go to the BAT B are black and brown. When I switch these wires I get power to the oppsite light. This is the secong switch I have tried, thinking it was a faulty switch. One question I have is there is two brown wires connected together That looks like they go to the voltage regulator? do they connect on the screw on top? Brian Nielsen Austin, Texas
John T (Pic test?)
10-29-2003 11:43:34
 Re: Re: 730 diesel electrical problem in reply to Deere Heaven, 10-29-2003 09:41:52
third party image
Deere, this is the first time Ive tried this, my ol buddy FIT Frank told me how, so here goes??? No warranties express or implied lol
Is this the same as your diagram and wire colors????? ??? It looks like the A and B circuits are from the battery posts, then the starter posts, then via the voltage regulator to the A and B switch terminals. Im unsure what top terminal on the VR you asked about???? The diagram looks like 2 brown wires do indeed hook somewhere on the top or side of the VR.
The bottom line is still regardless,,,,, You have to have a hot battery A and a hot battery B feed up to the switch. One is pos ground other neg ground and one from each battery bank via the ungrounded post and solenoid finally ending up on the A and B terminals on the switch.
1) Do you have that????? ??? (See my post below)
2) Are they BOTH hot????? ?
3) Will BOTH sides lights work at least if you wire/swap them somewhere and turn them on??? That is to test for lights working and a good ground to them.
Let me know.
John T
Clooney
10-29-2003 11:28:29
Deere Heaven, I can't tell by your above post which wire is now the hot one [the brown or the blue] but they BOTH [both the brown & blue] MUST be hot for both side lights to work.
~As I said below use a test light & verify BOTH [BAT A] & [BAT B] terminals have power. They BOTH must have power for those lights to function correctly. ~The blue is powered from the starter solenoid rear post & the brown is powered from the solenoid side post or [starter lug].
~It still sounds like you are missing power to either the brown or blue wire. If they are both hot then you have a switch problem...
~Seeing as both side lights work, at least one battery connector ground MUST be good & the lights grounds MUST be good�
~Does your tractor crank over ok? If not, post back as there could be a battery conector cable issue ONLY IF the tractor doesn't crank over..
[email protected]
Clooney
10-29-2003 09:07:16
Deere Heaven, it sounds like your light grounds are ok as each side does light. It also sounds like your battery grounds are ok or you wouldn't have ANY lights.
~SO,, That probably leaves your problem in one of the ign switch 12 power feed circuits to either the A terminal or B terminals, or the NON-WORKING lights are hooked to the incorrect light switch terminal.
~Your ign/light switch is powered by two 12 volt feeds originating from the starter solenoid, then to the voltage regulator, then to the ign switch terminal�s A & B�
~Use a test light & verify BOTH A & B ign switch terminals have 12 volt power to them [preferably one powered from each 1/2 of the batteries]. IF, you have 12 volts to both the A & B terminals on the ign switch then your problem is either your lights are hooked to the wrong switch output terminals, or the switch is defective....Your switch should have 2 terminals marked [HD],, one side�s lights hooks to one [HD] & the other side hooks to the other [HD]..
~If you need a wire diagram let me know?
[email protected]
John T
10-29-2003 08:46:30
Mornin Deere,
THERE OUGHT TO BE FEED WIRES TO BOTH THE A AND B SWITCHES INPUT TERMINALS, YOU MAY BE MISSING ONE OF THE HOT FEEDS FROM THE A OR B BATTERY BANKS (from the starter terminals or battery) if you only have one there. There shouldnt be any blank spaces on the A and B switch input terminals. Maybe youre just missing a hot hook up wire to the switch on the A or B side, they BOTH need one from opposite sides 12 volt battery banks????? ????? ? Use a voltmeter or test lamp to see if theres independant A and B feeds (both 12 volts) to the switches A and B inputs and both are hot. See below:
First, Im sorry but from your description I cant tell if u mean BOTH the A and B feed circuits to the A and B switch terminals are there and HOT????? ? So I will explain the sysytem and maybe u can figure it out I hope. If BOTH are hot, one 12 volts to ground POS and other 12 to ground NEG and all lights work, do the switches outputs (BOTH) to the lights get hot when lights turned ON ????? The switch should feed one side (A) thru to the lights on the A circuit and and the (B) side thru to the lights intended for the B circuit. If switching wires on the A/B input indicates only one feed wire is hot, see below to see why not. If only one switch output is hot regardless, the switch may be bad. It puts the A battery 12 volt side to one sides lights and B to other from what you seem to be saying , is that how its wired????? ? My diagrams also show different wirign if a 2 or 4 head lamp system, and it gets a lil confusing, so below are just general statements with a few needed guesses, sorry.
It would work if ALL lights are fed in parallell from a common 12 volt source from a light switch light output terminal, but that way only one battery is feeding lights while the other is not. Does the light switch have 2 light switch output terminals????? ? My diagrams show one feed to one sides lights and another feed wire to the others. If so, one sides lights are fed from the A battery side and the other the B battery side. If you have 4 batteries, two in series is A and the other 2 are B. The A and B battery circuits are the hot 12 volt feeds from the opposite sides battery circuits outermost ungrounded ends. The center tie point where the 12 volt sides are hooked in series needs to be bonded with a jumper to frame ground so theres 12 volts between the outermost ungrounded battery posts and frame, so lights and gauges etc work with one hot wire (pos or neg ground) to them and other to ground. One side battery bank is 12 volts to frame ground POS ground, while the other is 12 volts to frame ground NEG ground. The outermost unrounded posts are thus 24 volts to the ungrounded starter and generator and the A and B circuits to the switch. They use 2 independant circuits so each sides batteries gets equally loaded and runs 12 volt lights etc.
Sooooo use a voltmeter or test lamp and see if BOTH the A and B feed wires are HOT. The lamp to them and ground should glow 12 volts and not care if its pos or neg ground. They are fed from the outermost ungrounded battery posts from the battery or at the starter (it has BOTH batteries ran to it) and if one lacks a connection, the lights etc off that switches (A or B) terminal will not work.
You can swap sides etc to see if BOTH sides lights actually work,,,,, ,,, then see if the A and B input circuits are HOT,,,,, one is pos one is neg ground 12 volts, but lights dont care,,,,, see if the wires to the A and B inputs are fed from the OPPOSITE battery sides outermost untied to ground posts or at the starter where the 2 big cables lead. BOTH the A and B circuits have to be HOT at the switch (12 volts each) to feed its intended 12 volt loads.
If both sides lights are working, then they will work on either the A and B IFFFFF FFF the A and B are BOTH HOT.
Sorry, but I was just unsure if you yet know if BOTH the A and B switch terminals are HOT cuz they need to be. It may just be a missign hot wire connection from off the starter to the switch cuz BOTH sides need to be there and BOTH HOT and you may be missing one.
Let us know, post back any more questions or e mail [email protected] and hope we can get all the lights working. See if the A and B feeds to the switch are BOTH there and BOTH hot and if not trace back cuz each needs a wire to the starter or batteries to get its 12 volt source.
Good Luck n God Bless
John T
ron in MN
10-29-2003 08:31:19
I assume you have electric start, right? That's a 24 volt system and the lights are 12 volt so it's rather complicated to underzstand. The starting part of the system is 24 Volt and doesn't connect to the tractor chassis. The "center point" of the batteries connects to tractor chassis and half of the lights operate from 12 volt positive and the other half of the lights operate from 12 volt negative.
MIKE HANLEY
10-29-2003 08:12:30
My guess wold be the ground. On all ours, I run three wires up to the fenders. One for the inside light, one for the outside light and the third wire I groung to ome of the lights were the screw clamps the lens in. then I run a jumper wire between the two lights. Then when back at the dash, I ground the grounding wire to the steering casting. I have tried it without the extra grounding wire and have had the lights flicker when driving the tractor or had them go out completly. Have had no trouble since I starting useing the grounding wire.
