14T baler help needed
chubbygumby
09-22-2006 13:00:06
I have a 14t that bales great but every once in a while the needles will cycle and not stop and cycle 2 or 3 times making a heck of a knot. Anybody know what my problem is?
Thanks!
Ronbo B.
09-25-2006 12:15:45
 Re: 14T baler help needed in reply to chubbygumby, 09-22-2006 13:00:06
If you are saying that the needles come up to tie a new knot(for a new bale)....well that means it is tripping prematurely. The little curved arm (I call it a trip arm or bale measuring arm) has small grooves in it. If these get worn smooth, it could slip....then trip...making it cycle prematurely. Use a 3 cornered file or hacksaw to renew the grooves....Sorry if this is of no help. R.B.
chubbygumby
09-23-2006 05:35:00
 Where to get parts for 14T? in reply to chubbygumby, 09-22-2006 13:00:06
I was thinking it must be in the knotter clutch,
Where can I find parts? My local JD dealer cant help me
Thanks!
Bob
09-23-2006 08:16:28
 Re: Where to get parts for 14T? in reply to chubbygumby, 09-23-2006 05:35:00
You might want to clean of the knotter clutch of old grease that could cause the innards to stick, and closely check it over for worn parts.
Has the needle brake been checked for wear and proper adjustment?
Tx Jim
09-23-2006 03:41:31
 trip dog?? in reply to chubbygumby, 09-22-2006 13:00:06
I replied on you thread on other forum but I have another answer. After needles cycle there is a trigger of sorts that's supposed to catch to unlock dog inside operating drum. If this dog pivot gets loose or bent it will not unlock trip dog and needles will continue to cycle until dog gets unlocked. At least that's the way it is on 346's. See it's clear as mud. Tx Jim
johns48b
09-22-2006 20:08:33
on ih balers there is a way to tighten the brake up on the neddles so that they want drop down at the wrong time. but if your neddles are constantley going in and out something else must be wrong or the dogs would be flying up to protect the neddles from being hit by the plunger. is there a shear bolt in the neddle drive mechanisum that is sheared off but still looks like it still in one piece. i'd sure like to know the answer to this when you find out your problem. a direct em to me would be appreciated. if you don't find an answer let me know and i'll contact this jd mechanic that worded for jd for 61 years and as of this spring was still working 3 days a week.
lonzo
09-22-2006 15:27:04
I owned one of these balers for a while but i sure don't all there is about it, I would look at the needle brake and check and make sure that the neddle frame is going all the way back into home place. You really need a book to go along with this baler and some old gray haired guy looking over your shoulder who has worked on the reciving and dise charge end of the baler plus all the things in the middle.
