How do ya
Set crankshaft
09-22-2006 06:25:10
620 JD? I got a black dash 620, 58 model,, just got done rebuilding the engine, never had the crank out of the tractor, but had the flywheel off, the clutch is making some racket when its disenguaged, and I can hear the flywheel rubbing the tin cover ever so slightly. Ive loosened the flywheel, and shoved it over with like a .010 feeler guage and tightened it down. ( Clutch was not enguaged) Thats when it started making noise, so I quit, and decided to ask. Should the clutch be enguaged before I set the endplay?
buckeye al
09-22-2006 14:57:38
 Re: How do ya in reply to Set crankshaft endplay on, 09-22-2006 06:25:10
Frank is absolutely right. Having the clutch engaged or disengaged makes no difference on the travel BUT.... some books suggest engaging the clutch before starting the adjustment process.
Why?
Because once the clutch is engaged it becomes a good tool for moving the crank to the left. Pulling back gently on the clutch handle will move the crank left and having this "tool" to work with can make the flywheel adjustment process a bit easier.
I measure mine using a dial indicator set on the pulley and feel the tractor. I make an ajustment to the flywheel position then push the clutch forward & set the indicator to zero. Pull back on the clutch lightly & read the indicator. The clutch must have substantial snap to it so that it does NOT easily disengage when pulled back. Once you get the hang of it, I find it an efficient means of adjusting crank play and a lot easier than feeler gauges.
F-I-T
09-22-2006 13:22:26
I don"t think you should have to have the clutch engaged. If everything is correct, clutch in or out should have no affect. Be sure the crank is pushed and held to the tractor left when you move the flywheel in (that"s really all the steel nut is used for), and once set, .005-.010" total end play is the book setting.
Frank
