720 POWER STEERING
chile2
09-21-2006 17:08:27
HAVE A 720 THAT YOU CAN TO THE RIGHT WITH ONE FINGER BUT WHEN TURING TO THE LEFT HAVE TO USE BOTH HANDS ANY IDEAS ?????
Glen in TX
09-21-2006 21:36:16
 Re: 720 POWER STEERING in reply to chile2, 09-21-2006 17:08:27
It gives some good info in I&T JD-16 but better info in a JD SM2050 power steering service manual. You can jack up front end with wheels off ground and loosen bolts on lower pedestal bumping it back and forth with a drift and hammer to align it while it's running to see if turns easier or even each way but like FIT said it's usually those pins worn or actuator problems. Can price SM2050 on paper or CD disc SM2050CD also at http://jdparts.deere.com or call 800-522-7448.
F-I-T
09-21-2006 18:32:58
Chile2:
It could be as simple as bumping up the flow to the actuator valve, or as I suspect, flats and wear spots on the dowel pins and actuator sleeve cam face and springloaded cam. This puts a hitch in what was supposed to be a smooth sliding motion. Look back in the archives and you will find some lengthy discussions along with some diagrams that have been posted (I know I have some photos still in the archives).
Also, do as was suggested and get the book that JD offered just for the power steering systems on the Waterloo tractors. Read it several times (it's short) and once you understand things, you'll be able to perform some tests and adjustments. Not too many JD dealers have techs that have worked on those units on their staff anymore.
Frank
Ron Rayburn
09-21-2006 17:57:59
There is an adjustment screw on the Power Steering valve that will probably take care of your problem. Suggest you obtain a service manual or stop by your local JD dealer for this adjustment.
