Cylinder use on a 620
Randy G.
09-21-2006 12:48:05
I have an old B2161R cylinder for a JD B, 50 520. Can it be used with a JD 1958 620 on a 3 bottom plow?? This cylinder is the type that had the pins on each side of the main cylinder body. Just want to make sure I don"t break something.
Thanks for your help!!!!
Glen in TX
09-21-2006 22:18:21
 Re: Cylinder use on a 620 in reply to Randy G., 09-21-2006 12:48:05
Mike and Al are right about where to use which cylinders and pressures. You can use them all anyplace you want but chance blowing out seals and breaking those old cylinders on later higher pressure tractors. Here are pressure specs from JD SM2011 hydraulics service manual.
third party image
Leroy
09-21-2006 17:05:32
The cylinders 2 1/2" B, 3 1/2" A and G (diameter ?) culinders should never be used with any of the numbered tractors as they had too high a pressure for the A, B, & G cylinders, the numberd tractors only had 1,200# hydrolic cystems if the live pump and less for the PTO pump, Al is correct, do not try to use but for a 55ABH plow a 2 1/2' cylinder is large enough
bckeye al
09-21-2006 15:51:59
Others may correct me but I thought the lettered series tractors had hydraulic breaking pressures of about 750 or 1000 psi depending on age. These tracotrs used the two parallel rod style stop collar on remote cylinders that were painted GREEN.
The NUMBERED series tractors had breaking pressures of around 1500 psi and they used cylinders that had the stop collar sliding along the ram for stop adjustment and they were painted GREEN!
The new generation and all since have had 2500 psi destroke pressures and they use the sliding collar on the ram stops but the cylinder body is painted BLACK!
I suspect if you use the B cylinder on the 620 it will function just fine until it begins to leak out the head gasket, the ram packing, both or breaks.
Maybe we're too cautions but we have lettered, numbered and new generation tractors all in service at our place. We use Hygard in all of them except for the H. This way cylinders can be moved from tractor to tractor but GREEN cylinders NEVER get connected to the new generation tractors. Double rod ones go only on the lettered tractors! Black ones can go any place!
John Didde
09-21-2006 15:25:10
B2161R cylinder is for a John Deere B, The diameter of the bore is 2 1/2" it may not have enough power to lift a 3 bottom plow, it depends how heavy the plow is. You need a 3" cylinder. I have an website: www.greenstore.org it shows all 3 cylinders.
jddriver
09-21-2006 13:33:05
Same cylonder will be no problem
Johnnydee
09-21-2006 13:18:20
Am am not sure what Mike M is thinking but the pumps on the 520, 620, and 720 are all the same. The pressures are no difference. The old twwo cylinder tractor do not need a high pressure cylinder by any means they simply never see the high pressures that new cylinder see.
Mike M
09-21-2006 19:48:36
 Re: Cylinder use on a 620 in reply to Johnnydee, 09-21-2006 13:18:20
Those old cyl. are made for B tractors that run maybe 800 psi. And yes the 520,620,720 and 30 series all run the same pressure. I'm guessing 1500 psi ? unless it's turned up to lift a modern haybine.
So I'm thinking that that old cylinder is worth maybe twice what it would cost to buy a NEW cylinder so why risk tearing it up ?????
Mike M
09-21-2006 13:04:50
I wouldn't risk it. You should be able to sell that cyl. for more than a new replacement made for high pressure would cost at TSC.
