50 JD A brakes
Larry T
09-21-2006 12:05:58
Need to replace pads on brakes, have no idea how to remove drum. Has only holes on outside of drum. Are there any pictures that demonstrate the steps in replacing pads? Need help. I've looked at the "Discussion Board" but didn't find anything.
Pappy
09-21-2006 13:41:13
 Re: 50 JD A brakes in reply to Larry T, 09-21-2006 12:05:58
John T. is correct, but one more word of advice.
Before you take the wood block and push the shaft out of the housing, take a file and clean the shaft splines of any burrs or flash that has built up over the years. If not done, the burrs or flash on the splines will cut the bushing when you push it through, and worst of all, if you rotate the shaft when pulling it out of the bushing, the rough splines will act as a reamer and really carve out the bushing.
Now---really/truly I did not learn this the hard way. That"s my story and I"m sticking to it.
John T
09-21-2006 12:21:12
Larry, You have to remove the three bolts (one is stud n nut) so you can pull the entire brake assembly out of the side of the tractor. Then you remove the cotter key in the big castle nut on the end of the shaft n remove the big nut (keep track of washers n spacers) and then use an oak block etc to drive the entire shaft WITH BRAKE DRUM INTACT (its permanently attach to end of shaft) out of the housing. I loosen the adjuster bolt (square headed) first so the shoes are less tight against the drum. Then you can replace the shoes n springs etc as needed. I always clean n buff n polish all the cams n pins and apply anti sieze or silicone grease so things work smooth n dont rust together later. I also remove n clean n wire brush then use anti sieze on the adjuster bolt.
John T (NOT a brake expert but have done them and its a nasty messy dirty job I hate lol)
