720D w Pony Start - Throttle Problem
D-Man
09-21-2006 09:56:29
The throttle lever problem is as states: When the 720D w pony is running I can push the throttle lever forward and the motor engine revs as it should, but when I retreat the throttle lever back to the idling postion it does not come back down to idle, therefore I have to engage both brakes and engage the clutch to get her to settle down to idle speed again. Does anybody have some advice as to what to look for to correct this hyper old girl. Thanks for your consideration and comments.
Bob
09-22-2006 00:58:31
 Re: 720D w Pony Start - Throttle Problem in reply to D-Man, 09-21-2006 09:56:29
They sometimes "throw" governor weights.
Blksmok
09-21-2006 10:40:45
D-Man....pull the pump cover off and make sure the rack rod that operates the two pumps is free to move. The throttle/governor mechanism should move it one way and the spring on the pulley side should push it back to the idle position.
D-Man
09-21-2006 10:51:03
 Re: 720D w Pony Start - Throttle Problem in reply to Blksmok, 09-21-2006 10:40:45
I will try that and go from there. If this is not the problem what else could it be?
mjbrown
09-21-2006 11:06:05
 Re: 720D w Pony Start - Throttle Problem in reply to D-Man, 09-21-2006 10:51:03
Less likely possibility is something wrong in the governor or linkage to the rack. Blksmok is more likely right.
D-Man
09-21-2006 11:31:09
 Re: 720D w Pony Start - Throttle Problem in reply to mjbrown, 09-21-2006 11:06:05
Hey thanks you guys. I will look into it further. If that is not it I will re-post.
