Carb Question - All Fuel vs. Gas
Mean Green
09-20-2006 21:12:18
I have a brand new carb sitting in frnt of me that"s supposed to be for an A. I have a gas only tractor and my carb and this new carb look almost identicle, but the new carb had no recognizable numbers stamped in it. Definately no DTLX-71 anywhere. Is there a difference between an All fuel and a Gas only carb that is recognizable? Does it make a difference if I use one or the other on a gas tractor? The new carb has a few numbers on it, but they are hard to read. This carb has a long story behind it. Thanks.
Mean Green
09-21-2006 04:49:30
 Re: Carb Question - All Fuel vs. Gas in reply to Mean Green, 09-20-2006 21:12:18
I have determined it is a gas only carb. I'm deciding whether to purchase this carb from a guy and it's starting to look like it's a knock off he purchased for $400 a few years ago. Basically he bought it, it didn't solve his problem when put on the tractor so he drained the carb and put it back in the box and it's been on a shelf ever since. The box does list a company in Rock Valley, Iowa. The research continues!!!
Duane Larson
09-20-2006 21:26:02
Mean Green,
Four carbs were used for the late styled A's and B's - for the A DLTX71 was the gas carb and 72 was the all-fuel carb. For the B DLTX67 was the gas carb and 73 was the all-fuel. The easiest way to distinguish the gas from all-fuel carb (if you can't read the numbers) is to locate the economizer plug - the all-fuel carbs have them (like all earlier carbs, which were all-fuel), but the gas carbs do not have an economizer plug - the econ circuit is different on the gas carbs.
Does your carb have a round disk near the top middle of the carb - it will have DLTX107U or 108U stamped in - those were the last carbs built and were "universal".
Or it could be one of the various attempts at reproducing the carbs, most of which have been failures.
