48 A
playfarmer
09-20-2006 19:03:12
If I put a single 12 volt battery in my 48 a do I have to leave it postive ground? Currently it has two six volts. If so can I jump start it without damaging the alternator on my pickup? Thanks
Hayfarmer
09-20-2006 19:36:00
 Re: 48 A in reply to playfarmer, 09-20-2006 19:03:12
You can safely jump start from your pick up or other negative ground source, just be sure to put positive cable to positive and negative to negative, not hot to hot and ground to ground, also don't have vehicles touching. You could use 1 12 volt instead of 2 6s, just get a heavy 12 volt battery. No real reason to change over to negative ground unless you go to an alternator.
Pappy
09-21-2006 13:45:28
 Re: 48 A in reply to Hayfarmer, 09-20-2006 19:36:00
Just as Hayfarmer says, you can do it. I always tell my helpers before jumpstarting, read your battery--don't read the cables.
playfarmer
09-20-2006 20:01:26
Thanks for the advice. Really appreciate it!!!!! !!!
