3020 3 point quit lifting
mike1111
09-20-2006 14:07:50
was digging post holes and the last hole the digger went down and stopped digging, i started to bring it up and it grabed and screwed itself into the ground. stopped the pto and lifted the digger and it was to tight to pull it out so i unbolted the auger, but the now the 3 pt. won"t lift. i checked the cable and it"s pulling the lever under the seat. so where is the next place to look? thanks for any help. mike
msb
09-20-2006 19:57:00
 Re: 3020 3 point quit lifting in reply to mike1111, 09-20-2006 14:07:50
One of two places.Could be the thermal relief valve has popped open or crapped out.It is located on top of the 3 pt. valve housing under the right side of the seat and at the rear of the valve housing. Think it takes a 9/16" wrench to fit the plug-----or it could possibly have blown the o-ring on the 3 pt. piston.
lonzo
09-20-2006 23:30:35
 Re: 3020 3 point quit lifting in reply to msb, 09-20-2006 19:57:00
My helper had a 3020 the other day and the pressure regulator valve was hung up, see if the remote valve works, if it doesn't then check the pressure at the regulator valve(2250PSI at 1900RPM)
