Clutch Drive Pin
Green
09-20-2006 13:17:18
My clutch on a "40A does not snap in good, although it usually will snap out rather well. After a few engagements/disengagements, the clutch will loosen up and re-torqing of the adjusting bolts must be performed.
The adjusting bolts have been evenly tightend to around 20 ft. lbs. The dogs and toggles seem to be in decent shape although some minimal wear is present.
The clutch drive pin is loose, allowing the operating sleve to rotate slightly. There is enough rotation in the operating sleve that the dogs are showing slight wear on the sides where they are contacting the dog brackets.
I feel that my problem is with the drive pin. If so, how do I correct the issue without buying a clutch/pulley assem. that is new to this tractor? If something else is the issue, please let me know.
Thanks...
Mike M
09-21-2006 04:38:12
 Re: Clutch Drive Pin in reply to Green, 09-20-2006 13:17:18
I'd say that loose fitting pin is going to cause those problems you described.
Different model tractors have that pin put in differently. Some go clear through and you can see the end over on the clutch disk side others have a blind hole. The ones I have fixed had the hole egg shaped in the operating sleeve and the pin was worn. I welded or brazed the hole back round and installed a new pin. You can maybe even make an oversized pin and press it in.
