JD 310a Ring Gear...More info needed
Patrick Bourgeo
09-20-2006 11:54:08
I am despret :) Need more information... All hoses,bracket,wiring are revome, all bellhousing bolt also, there is noting left ( i check so many time) my probleme is that I am not able to split the engine from the transmission, I have a small gap of 1/8 of a inch all aroun the bellhousing meaning that all bolts are well remove... When I use a pry bar to move the engine away it feel like a spring pulling back the engine on the transmission, I went to the John Deer dealer neer my place and the service adviser told my that it was only a shaft whit spline in beetwin the to picece.. Did try to jack the diff and the transmision hoppppping it will help but Nooooo ooo, did use 2 chisel in beetwin the engine and trans.... Feel to hard to go in, maximum I was aloud to get was 3/8 of a inch and when I remove the chisel the engine go right back to where it fu..... belong :) back to square one... Can someone tel me what I need to split the engine from the transmission... Thanks
Patrick
PS: There is no acces door on the transmision or bellhousing to remove inside bolt like we use on car whit automatique transmission ...
Jonathan in MA
09-20-2006 19:25:30
 Re: JD 310a Ring Gear...More info needed in reply to Patrick Bourgeois, 09-20-2006 11:54:08
Its been quite awhile but I seem to remember two 3/8 bolts that are just behind the head... that attach a piece of the cab to the top of the flywheel housing... they arent very visible and tend to give that spring action when overlooked...
Patrick Bourgeois
09-21-2006 18:13:44
 Re: JD 310a Ring Gear...More info needed in reply to Jonathan in MA, 09-20-2006 19:25:30
Thanks for the reply, unfortunatly these 2 3/8 bolts where remove... Still looking for advise :))
Roy Suomi
09-20-2006 18:38:57
I'll bet the clutch splines are stuck on the input shaft..Probably not from rust but from the shaft splines being worn nearly through and catching on the clutch disk..Try turning the engine back and forth to dislodge the worn splines from the disk..
Patrick Bourgeois
09-21-2006 18:21:45
 Re: JD 310a Ring Gear...More info needed in reply to Roy Suomi, 09-20-2006 18:38:57
Thanks for the reply, I did try to turn the engine clockwise and counter clockwise but nothing, I will try-it again using more torque.. Will have to chain the front and rear using a chain block... Ouch, scare of the potential damage...:(
