Mike: When I was rebuilding my 70D I found that of all the gears still offered by JD, the set for the 70/720/730D's were not available new. I mounted my gears on an arbor, and while turning, took down the "tips" of both gears with a grinder so that the lenth of the teeth were a bit shorter than the depth of the mating gear node or trough. I also watched the relative tooth pitch (width or thickness) as compared to the pitch of the node. Since my tractor was a power steering model, the fan shaft bearings are mounted in a block that is only 3 1/2" thick or so, with a stub shaft protruding. I mounted this stub in my drill press, with the governor case attached, set the gears to a good state of rubbing and sat there while it turned, oiling a squirt at a time. Then I removed a shim or two on each side, and ran it some more. After several sessions, I was able to check the contact area using some Prussian Blue dye just as you would set a differential ring gear and pinion. Once the contact area was back in the normal zone, I set the heel and lash again on the low side and ran the set for an hour under an oil drip. At the end of the hour, I gained only a couple of .0001"s (1/10,000th) so I called it good. After installation, the gears ran quiet, the stub shaft play was quite minimal, much like the manual suggested, and they continue to run very quiet to this day. The key was dressing off the tips of the teeth that can cause interference, which I believe, is where the majority of the noise comes from when someone tightens up an old set. Using this method I have successfully re-paired many used sets that I think would have been tossed. I never saw the need to use llapping compund as the gears seem to erode each other fast enough as it is. I did fab a fixture to hold non-power steering type fanshafts and use an old 1/2 hp electric motor to turn it. A combination of sheaves keeps the speed at a safe level. Frank
