37 B Countershaft removal
Courtland
09-20-2006 06:49:49
If I've got the sliding gear shaft out, can I remove the countershaft by pulling the left bearing to buy some room so as to not separate the rear axle from the case??
thank you
Bob Collins
09-20-2006 19:33:13
 Re: 37 B Countershaft removal in reply to Courtland , 09-20-2006 06:49:49
Courtland, Sorry to tell you but on those 4 speed Bs the rear axle has to come off and the differential has to come out then the c-shaft slips right out. It isn"t really that bad and allows other repairs more easily. Just use care blocking up the front support (frame) and the rear axle rolls away quite easily with the power lift/rear cover removed.
